Control arm bushing failure
Has anyone had issues with their control arm bushings particularly the front uppers after installing LG coilovers and sway bars? It seems that after running the coilovers and sway bars I was having clunking noises during hard braking even while going slow and hitting the brakes hard.
I'm not ready to drop $2k to go to spherical bushings, so what would be alternatives until I do the upgrade?
The following 2 users liked this post by ttx350z:
Borg Motorsports (05-05-2019),
Pb82 Ronin (05-04-2019)
Supporting Vendor
Delrin looks like a great alternative to sphericals. Around 50%+ cheaper depending on brand.
https://www.borgmotorsports.com/coll...=4691915440162
To the OP - The stock bushings wear out quickly if you are driving the car spiritedly, even on a stock suspension. It's just a compromise GM made between the people that want a proper suspension and the people that want a "sports car" that rides well.
Borg kit is excellent. I have it on my car.
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
I'm almost certain it is your sway Mark. You need to check it loaded and unloaded. And check the end links. You should be able to easily install and remove the bolts. They should be set so that they are easy to install at a normal loaded position, and make sure the bar is set (centered rotationally) in the bushings so that it can have full rotational travel in both direction. When I install a sway bar, I attach the second end link with the tires on and a full load on the car. This way I am assured there is no pre-loading on the bar and there is no bias to either side.
Also, when you are ready to move to a proper control arm bearing (spherical), just call Mark at AMT and be done. Nothing beats a monoball for our use, period.
Supporting Vendor
FWIW a little bird has told me that AMT is gonna be running a big sale over Memorial Day. Just saying...
And yes, those uppers are prone to extrude themselves over time and track abuse. You can get a brand new upper for about $85 if you just wanna stick with stock for awhile.
While chasing suspension issues, I put a camera on the suspension of my new (to me) c6z and inadvertently found the 13 year old bushings are shot. Watch how much the knuckle pivots and translates under medium-hard braking.
https://youtu.be/AHS56igk6KI
