C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Need feedback on motor mounts
Old 05-08-2019, 12:49 PM
548chevelle
548chevelle's Avatar
Default Need feedback on motor mounts
Anybody have feedback on the AMT motorsport Vulcan motor mounts? Or other motor mounts. Thanks
Old 05-08-2019, 01:09 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Heard nothing but good things besides a little add NVH. I run the hinsons for past 6+ years and zero issues. No failures, work great, and no bad vibes. Can't go wrong with either I think.
Old 05-08-2019, 01:22 PM
phxcobra
phxcobra's Avatar
i have pfadt solids on the car. Have had issues with false knock. If i had it to do over, i'd go with the AMT mounts no question. my switch out at some point in any case.
Old 05-08-2019, 01:28 PM
freddyvette
freddyvette's Avatar
I use stock mounts with additional heat wrap and shielding. My set was replaced at 25k miles and I now have 63k miles. This is with long tubes. They are still going strong and I check them periodically
Old 05-08-2019, 02:48 PM
Mark@AMT Motorsport
Supporting Vendor
Mark@AMT Motorsport's Avatar
If it's a grocery getter or commuter I recommend sticking with stock. If performance is the name of your game and you can scarifice a little more NVH they keep the engine from moving in any direction and vibrations are damped with rubber throughout the mount. They're also gauranteed for life. Finally if you put them on and hate them I'll give you a refund, but that sucks to do a motor mount job twice just so I just try and be honest up front and let people know that it is not a cushy, stock-feeling mount.
Old 05-08-2019, 07:57 PM
Mordeth
Mordeth's Avatar
Received 1,678 Likes on 878 Posts
2018 C6 of Year Finalist
St. Jude Donor '10, '17
I use Mark's (AMT) Vulcan motor mounts. A tad bit more NVH, but it doesn't bother me in the slightest. Very well manufactured pieces that do their job.
Putting heat wrap on the stock mounts is like putting a blanket over a stuck pig. It's still a pig, and a leaky, fat, cushy one at that. If you are going to replace them, do it right and once and for all.
mykream (05-14-2019)
Old 05-11-2019, 03:09 PM
Michael_D
Michael_D's Avatar
I installed Hinson mounts. That was before the AMT were available, or I probably would have installed them. I was a bit concerned that the semi-solid type mount would introduce engine vibration/nose to the car. In all honesty, if they did - I can't tell. Road noise from the tires is more than whatever the mounts may transmit. I like how the car's front end lifts with the aftermarket mounts. With the OE mounts, the front right would always lift higher than the left. Front end lifts even now, which should equal better power transfer to the rear wheels.
Old 05-11-2019, 10:02 PM
freddyvette
Mine haven't leaked for 40k miles with headers installed. If you introduce heat you're going to have to add shielding.
Old 05-11-2019, 10:06 PM
Pounder
1/4 mile/AutoX
Support Corvetteforum!
Pounder's Avatar
Received 2,081 Likes on 1,634 Posts
We installed Hinson mounts on our 2006 Z 06 and made night and day difference, stock ones were shot !!!!
Old 05-11-2019, 10:24 PM
Mordeth
Mordeth's Avatar
Not with the AMT mounts. No heat shielding needed.
Old 05-11-2019, 10:46 PM
freddyvette
Right but I do frequent 1000+ mile trips with my car so I decided those are too stiff for my taste.
Old 05-11-2019, 11:08 PM
tw78911sc
tw78911sc's Avatar
How much effort is involved with lifting the motor enough to swap them out?
Old 05-11-2019, 11:18 PM
Pounder
1/4 mile/AutoX
Pounder's Avatar
if I remember right had to remove exhaust at manifolds, pain in a** !!!!
Old 05-12-2019, 06:19 PM
sccaGT1racer
sccaGT1racer's Avatar
Cannot go wrong with either hinsons or amt. I personally have hinsons because I purchased them before the amt mounts came out. I didn't notice any added nvh in my car.
Old 05-13-2019, 03:19 PM
moose.b3
moose.b3's Avatar
Hinsons
Old 05-14-2019, 10:30 AM
ConfusedGarage
ConfusedGarage's Avatar
I installed Hinson motor and trans mounts around 10,000 miles. The stock ones were shot and all the fluid had leaked out. The Hinsons barely added any NVH, but I do recommend wrapping them to cope with heat so they dont melt. I take my car on cross-country road trips, so I couldn't go with something that rattled my teeth out.
Old 05-14-2019, 07:54 PM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
This is the no-BS review I've been waiting for. I've had them in the garage for over a year hesitating to install them due to potential increase in NVH. Thanks!
To Need feedback on motor mounts
Quick Reply: Need feedback on motor mounts
