[Z06] Finally Getting The 08Z06 Dyno Tuned
Currently at Norris Motorsports getting tuned. I had some mods done back in 2017 starting with an AHP heads, ported and milled .020" to address the head issue. While addressing the heads I went ahead and added B&B LT's, no cats. The car already had Akra Evo system and K&N air tube and filter, but I recently modified Haltech Beehive to clean up engine bay. I won't have a baseline to compare as I originally sent the ECU to ECS for their mail order tune, not the best route to go IMO. After mail order tune I was having some hanging idle issues and intermittent codes, Service Traction Control and Service Electronic System would pop up intermittently. Apparently I'm being told that pretty much every code that could set the SES light was disabled and car was running lean via the fuel trims at idle and cruise and before any wide open pulls could be done 8% more fuel needed to be added to complete fuel table, even with that, the first dyno run was quite lean. Norris is still currently working on it to dial her in, I'll post results later.
Landru (05-13-2019)
Dyno results are in, 490 RWHP, 458 RWTQ. I'll be picking it up today and post printout later. The main reason for the tune was fixing the hanging idle issue and was hoping this would also fix the intermittent Service Traction Control and Service Electronic System that kept popping up. I suspected issues were because of the ECS mail order tune, guess I was right. I wonder what the HP is at the crank?
St. Jude Donor '12-'13-'14
The hanging idle could be tune related or an unmeasured air leak related because if you didnt add an aftermarket camshaft, you really dont need to change the idle characteristic.
Supporting Vendor
Received 1,012 Likes
Looks like you picked up right at 42rwhp from our ported heads and LT's!!!
I bet she feels nice and strong now!
We typically see a 60-70 HP delta from the engine Dyno to the Chassis Dyno... So at 490rwhp you will be right at 550-560bhp. New vehicles (like the C6z06) are much more efficient at transferring the power from the engine to the rear wheel. We observe a much greater Delta on older vehicle with less efficient drive lines.
https://www.americanheritageperformance.com/
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Sorry to hear there was an issue with your tune, however, I do not "shut off all codes" ever, so unfortunately from that point on I cannot take this seriously, but more of an "I'm a hero tuner" response that was given to you. I am seriously happy that you are happy with your car though, best of luck to you with it.
HERO TUNE
Don't add thousands of dollars worth of parts and go cheap with a mail order tune OP. ECU calibrations are extremely important to the life of the engine.
