ZR-1 clutch in a Z06
So what parts do I need to mount a ZR-1 Clutch in my 06 Z. I currently have a Monster Lt-1 an it is very noisy. At my horsepower levels 540 rwhp a ZR-1 clutch do be quieter an OK for my needs.
What you have is better that the LS9X clutch kits...and much cheaper,
Zr1 is a downgrade and no one should be using it since the newer c7 stuff is an upgrade.
Monster LT1-S. I’d buy it again when it’s time for a replacement.
Mine is dead silent. What noise does yours make?
I had a Katech LS9X in my ~630rwhp Z06 with good results. I had a carbon twin disk in it, but I didn't like how it drove at all (too noisy). The organic clutch didn't track as nicely (slight delay to disengage), but for the street it was fine.
The LT1-s is a c7 clutch. Which is a newer/better design of the OEM dual disk setups, and the ls9 is has a worse design and isn't nearly as good.
If it is making noise, you have an issue to fix.
My stock C6 ZR1 clutch is holding my 672rwhp just fine. If it ever goes out, I'll definitely look into the LT1/LT5 clutches.
Not a downgrade compared to stock c6z but to what he has and a c7 clutch.
