Anybody try this tiresize combo?
Has anyone tried?
285/30 r19 front
325/30 r19 rear
The rear diameter is exactly 1" larger with a ratio of r/f ratio 1.039...
285/30 r19 front
325/30 r19 rear
Are you concerned with the difference in diameters throwing a code? I run 295/30-19f and 345/30-19r which is 1.25" difference and I have no issues.
Yes. I've been reading conflicting info regarding the margin of error the abs traction system can tolerate. I've read within 3% of original diameter, I've also read a rear front ratio of 1.04.
I'd like to keep the diameter taller in front that the standard 275/30 19 size that everyone else uses.
For what it's worth those are both OEM sizes but in different combinations. Based on that I would think you're fine.
285/30R19 is OEM Z07/ZR1 size (335/25R20 rear)
325/30R19 is OEM GS/Z06 size (275/35R18 front)
Racingswh (05-31-2019)
