C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Advertisement
A lot of metal shavings on oil pan drain plug
Old 06-24-2019, 03:59 PM
Dan_the_C5_Man
CF Senior Member
Dan_the_C5_Man's Avatar
Originally Posted by Jfryjfry View Post
Not sure why there wouldn’t be the same in the filter, but that doesn’t mean your motor is borked. It could be debris from the previous incident and, with luck, it is being filtered out and settling in the pan.
Although it might be chewing up the pump.
If it isn’t leftover from before, I’ve seen the sides of the connecting rods get chewed up and maybe that’s what’s happening here.
Connecting rods are Ti, and Ti is not ferrous (won't stick to the mag plugs).
Dan_the_C5_Man is offline
Old 06-25-2019, 01:18 AM
Jfryjfry
CF Senior Member
Ahhh of course!
Jfryjfry is offline
Old 07-09-2019, 12:33 PM
hy_bmw_freak
CF Senior Member
any update ?
hy_bmw_freak is offline
Old 07-10-2019, 12:04 PM
spartan8270
CF Senior Member
.0020-.0030 is too large to run on the mains. .0015-.0020 on the mains is good with 5w-30 and .0018-.0022 on the rods. Remember with the aluminum block, the clearances are going to open up once up to temp more than an iron block will.
There are a lot of places for metal shaving to hide in a LS. Especially in the passageway where the oil restrictor barbel lives.
spartan8270 is offline
Old 07-10-2019, 04:56 PM
meanjoe
CF Senior Member
Support Corvetteforum!
meanjoe's Avatar
I'd also like to know what happened. It would also be nice to know if that pile of shavings in the first picture is dime size or fist size?
meanjoe is offline
Old 07-10-2019, 05:06 PM
SilverBulletC6Z
CF Member
SilverBulletC6Z's Avatar
So I decided to just pull the motor and figure out where those shavings are coming from, would be a shame to destroy new cylinder heads trying to ignore an obvious problem. Motor is halfway out should be fully torn down by end of this week.
The shavings were a bit smaller than the size of a dime, probably closer to a 1/4” - 3/8” ball.
I think the shavings may be pushrods rubbing on the cylinder heads, not sure yet could be anything at this point.
SilverBulletC6Z is offline
Old 07-11-2019, 02:08 AM
73DBG
CF Senior Member
73DBG's Avatar
One thing I learned during my rebuild was probably the most important thing to do is measure pushrod length....several times with an actual tool. My engine builder was very very meticulous about this, we sent two sets back and almost ended up sending the third back and we were gonna have cam motion make us a custom length, but the third set end up measuring almost perfect only way to get any more ideal would have been a complete custom set measured individually.
Main bearing clearance is another big deal, LS7 is tight and can be even tighter when you open up the bottom end and use coated bearings another reason why I use 5W30 dudes make big mistakes chasing higher hot idle oil psi so they throw thick oil at it and that doesn’t end well.
Keep us posted man, definitely sub’d hate this happened again man, the stress level of **** like this is not fun.
73DBG is offline
Quick Reply: A lot of metal shavings on oil pan drain plug
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
