C6 Corvette ZR1 & Z06 General info about GMís Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Advertisement
[Z06] Which plug wires?
Old 07-11-2019, 09:00 AM
Uncle Meat
CF Senior Member
Uncle Meat's Avatar
Default Which plug wires?
I'm installing headers on my car and was contemplating replacing the spark plug wires and adding some thermal sleeves while I was at it. Good idea? If so, do I want straight spark plug boots, or 45į angled boots?
U.M.
Uncle Meat is offline
Old 07-11-2019, 10:07 AM
dcamick
dcamick
Support Corvetteforum!
dcamick's Avatar
They work for me.............
dcamick is online now
KurtsZ06 (07-12-2019)
Old 07-11-2019, 10:54 AM
Unreal
CF Senior Member
Unreal's Avatar
Received 1,476 Likes on 1,254 Posts
Thermal sleeves seem to cause more issues than they fix. Cooks the wires inside. What is important is an air gap, and with the sleeves typically you don't get a gap, which then just turns them into little overs that bakes the wires.
Firecore are the best IMO, but normal GM ac delco, with stock heat shields work great for $55.
Unreal is online now
Old 07-11-2019, 04:31 PM
dcamick
dcamick
dcamick's Avatar
Pushing 824 HP.....That has never happened with these KoolMat Heat Socks, Mooresville, NC....
Old 07-11-2019, 05:38 PM
Unreal
CF Senior Member
Unreal's Avatar
Nice, my car made 1200+ and ran no heak socks and had no issues, so what is your point? In general the heat socks do nothing, and when setup wrong actually hurt. It is about proper fitting plugs with a nice air gap.
Old 07-11-2019, 05:40 PM
dcamick
dcamick
dcamick's Avatar
My Point: They Work
Your Point: They Don't
Simple!
OP: Like Unreal stated, if you fit good heat resistant wires properly in relation to the header locations.....you should be good!!
Old 07-11-2019, 05:51 PM
Unreal
CF Senior Member
Unreal's Avatar
Define work? If plugs last just fine without them, then what exactly are they doing? Seems like a waste of money best case.
Old 07-11-2019, 05:53 PM
dcamick
dcamick
dcamick's Avatar
Ok!
Old 07-11-2019, 05:56 PM
oemtech
CF Senior Member
oemtech's Avatar
I run SS Solid Core wires with an RF choke. No heat issues or radio issues.
oemtech is offline
The following 3 users liked this post by oemtech:
dcamick (07-11-2019), KurtsZ06 (07-12-2019), Uncle Meat (07-12-2019)
Old 07-11-2019, 08:59 PM
jimbob8915
CF Senior Member
jimbob8915's Avatar
Some more info on these wires please.
jimbob8915 is offline
Old 07-11-2019, 09:39 PM
realcanuk
CF Senior Member
realcanuk's Avatar
St. Jude Donor '13
If moving away from stock, firecore is the best out there.
realcanuk is offline
Old 07-11-2019, 10:08 PM
oemtech
CF Senior Member
oemtech's Avatar
SS Solid Core wires are an offshoot of wires that were custom made for the 8.1L Chevy used in the RV's. I use to sell them. The only difference between what was used on the 8.1 and mine are the length.
If there is enough interest I might be able to get a few sets.
OBTW - The shields are required IIRC (Rockauto - $4 per)
oemtech is offline
Old 07-12-2019, 08:21 AM
KurtsZ06
CF Senior Member
KurtsZ06's Avatar
These completely solved my feedback noise issue and, eliminated a pesky random misfire. Excellent plug wires.
KurtsZ06 is offline
Old 07-12-2019, 11:20 AM
reasonable suspicion
CF Senior Member
Is Katech doing their rocker covers and coil mounts? If so run the stocks and let them do the different wires while they have it. I think they used msd on mine with socks and no issues. However the firecore have great feedback, I thought about changing but havenít had issue so havenít
reasonable suspicion is online now
Old 07-12-2019, 12:50 PM
Michael_D
CF Senior Member
Michael_D's Avatar
I love the Firecore Pro-Mod boots. They click onto the plug with a reassuring click, do not come off, and you can bend them slightly as needed to get them away from the header tubes. You can buy them in any length too, which is a bonus.
Michael_D is offline
Brandon619 (07-13-2019)
Old 07-15-2019, 08:10 AM
jwp2
CF Senior Member
Can someone post links to buy these? THE WIRES, the heat shields, etc.
I burned a couple coil wires at the track this weekend and need them ASAP.
jwp2 is offline
Old 07-15-2019, 09:55 AM
Michael_D
CF Senior Member
Michael_D's Avatar
https://www.customwiresets.com/customize.php
For a quicker turnaround, call them. Tell them you want the pro-mod boots.
Old 07-15-2019, 09:57 AM
Unreal
CF Senior Member
Unreal's Avatar
Mark Carlye typically stocks the firecore50 sets too.
http://carlyleracing.com/
Old 07-15-2019, 10:25 AM
Mordeth
CF Senior Member
Mordeth's Avatar
Received 1,094 Likes on 645 Posts
2018 C6 of Year Finalist
St. Jude Donor '10, '17
Same as Nick. Get mine from Carlyle. He usually has them in stock. Use them on my race car and work great.
Mordeth is online now
Old 07-15-2019, 11:55 AM
ANazir
Junior Member
ANazir's Avatar
I use Firecore 50 wires that i got quickly from Carlyle Racing.
ANazir is offline
Quick Reply: [Z06] Which plug wires?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
