C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Wet Sump vs. Dry Sump
Old 11-24-2004, 09:38 PM
Pilot135R
Pilot135R's Avatar
Default Wet Sump vs. Dry Sump
Hello All,
Please explain the difference between a wet sump and a dry sump. What are the advantages and disadvantages of each type?
Thanks!
Bobby
Old 11-24-2004, 11:29 PM
LoneWarrior2552
LoneWarrior2552's Avatar
Old 11-25-2004, 12:35 AM
ColdSmoke
ColdSmoke's Avatar
http://auto.howstuffworks.com/question331.htm
Old 11-25-2004, 02:58 AM
LS6v
LS6v's Avatar
This is from Sportscar International Magazine January 2004:
...the new M5 requires some careful thought. In an ideal world, a race car-stlye dry sump would have been used, but this system has its own drawbacks in a road car application, such as the added expense and packaging the the (their typo) external reservoir. BMW came up with what it terms a "quasi-dry-sump oil system." To cope with cornering forces beyond 0.6 g, the motor has two electric oil pumps, controlled by a lateral g-sensor, which pick up oil from the outer cylinder head and pump it to the main oil sump. The main oil sump has a continuously variable control to deliver the exact amount of lubrication required by the motor for the given conditions.
That should give you an idea of how a dry sump kinda works with out external reservoirs / packaging.
Old 11-25-2004, 05:35 AM
Guru_4_hire
Guru_4_hire's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
a wet sump is what you are used too, a big oil pan on the bottom of the engine holding the oil with an oil pump and pickup immersed in the oil.
A dry dump is a completely different beast(I looked into one for my C3). it has an external oil pump, and the oil pan is just a big pickup on the bottom of the engine for the external oil pump. You can have multiple stages on the oil pump to pickup oil from all sides of the pan when you are cornering so oil doesnt buildup in the pan and cause drag on the rotating assembly. The oil then travels from the pump into a big tank in the 10" diameter, and about 16" long. the oil is squirted into the top and air bubbles from being whipped by the oil pump, is removed by running down a series of plates. the oil is then sucked by another stage of the oil pump through the bottom of the tank, and back into the engine. It also creates a certain amount of crankcase vacuum which helps your engine too.
The drawback is where do you put the great big 3 GALOON oil tank. and cost. complexity. etc.
Old 11-25-2004, 06:08 AM
427 C5
427 C5's Avatar
Originally Posted by ColdSmoke
Great article and links!
Thanks for the info Coldsmoke.
Old 11-25-2004, 08:14 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Drysump has advantages for dedicated track cars (increased oil capacity, better oiling in corners), but actually has more parts to break and increases your center of gravity in most cases. I see no advantage in a street car, and actually would prefer them NOT put it on the Z06
Old 11-25-2004, 11:10 AM
ivan111
ivan111's Avatar
Originally Posted by Pilot135R
Hello All,
Thanks!
Bobby
Lowering that engine mass center of gravity is one big advantage of the dry sump lubrication that alone will improve the handling......
Old 11-28-2004, 10:03 PM
davidfarmer
this last statement is NOT correct
Old 11-30-2004, 02:20 PM
wachuko
wachuko's Avatar
The lower center of gravity comes from the ability to lower the engine more (similar to what they did with the Porsche Carrera GT). But you need to take into consideration the location of the external oil tank to determine the overall improvements. Porsche went with a smaller carbon fiber clutch that allowed lowering the engine even more.
It is my understanding that one of the major advantages of dry sump is to avoid oil starvation during high speed (G) cornering.
I will let those that have more knowledge in this are to chime in... ...but I for one would like the Z06 to come from the factory with dry sump...
Old 11-30-2004, 03:05 PM
Painrace
Painrace's Avatar
"OK", guys, from a retired race car driver, performance guys will love the dry sump system. In a race car the center of gravity can be lowered because the bottom of the oil pan is just a few thousands below the crank. This will improve cornering.
The oil is sucked out of the pan by two or thre oil chambers on the dry sump pump and put into an external tank. The oil pump sucks oil from the external oil tank and forces it through an oil cooler and into the engine to lubricate. You never have oil starvation. A Weaver dry sump pump will last almost for ever is you don't get any foreign parts into it. Race engines are know to blow up!
The dry sump sucks air as well as oil from the top of the engine which means no valve cover oil leaks. It also means you have to get rid of the air. We calculated the air moved through the engine was about 55 gallons per minute at race RPMs. We placed large hoses from the top of the oil tank back to the top of the valve covers and used the same air over and over. A breather was placed on top of the oil tank to allow fresh air in or too much air out.
There is a big improvement in throttle response with a dry sump motor and internal engine lubrication problems at high G forces are almost eliminated. I am counting on a dry sump system and a engine oil cooler. The engine oil cooler will be a problem in very cold temperatures. We could not get the oil temperature up with out completely taping the air off when ambient was at 45 degrees or below. I don't know how GM will handle this. Thick oil will smear the bearings in almost no time.
Just my two cents.
Old 11-30-2004, 06:42 PM
LTC Z06
Get Some!
LTC Z06's Avatar
Did you read the post above you? Your question has been answered, we don't need the extra cost and capacity, only a serious, dedicated race car needs a dry sump system.
Old 12-01-2004, 08:36 AM
Guru_4_hire
Cruise-In V Veteran
The only problem with the dry sump theory is the placement of the oil tank. they arent exactly small.
Old 12-01-2004, 10:21 AM
Bwright
Bwright's Avatar
It in fact is correct.
Old 12-01-2004, 10:38 AM
Bwright
Bwright's Avatar
The post above contained the following sentence:
"There is a big improvement in throttle response with a dry sump motor and internal engine lubrication problems at high G forces are almost eliminated. I am counting on a dry sump system and a engine oil cooler. " (My boldface). Why would you think a high-performance Z06 would not need technology considered a requirement for other such extreme road cars as the Carrera GT, Murcielago and Enzo? Don't say cost because the Z06 has always incorporated expensive technology (titanium exhaust, carbon fiber hood) at significantly lower cost than the competition.
With a declared mandate to noticeably increase cost and significantly increase the performance envelope it should be a given that the car will have a dry-sump oiling system. Whether or not they will do it remains to be seen but if they want to go to that next level they had better be seriously considering it because that is where the serious players are.
Old 12-01-2004, 12:01 PM
wachuko
wachuko's Avatar
...only a serious, dedicated race car needs a dry sump system.
I think I understand your line of thought... ...you do not want additional complexity or cost that will add to the price of the car...
Do know that 911 have had them since birth... It goes with the fact that the cars sold to the public were somewhat close to the cars raced. You could take your 911 to the track knowing it was built for it...(BTW, not the case today for the 996 and 997... only the GT3 are close to the cars Porsche sell for racing everything else is lower quality mass produced wet sump that they try to pass as a dry sump...)
It is clear that GM wants to keep its customer base but also wants to expand it and they have targeted 911 buyers. It will be a plus for potential customers of 911s the option of a Z06 with a dry sump... just one more feature that will appeal to those that do like to track their cars (even if it is not a dedicated track car).
Just as a car freak and even if I do not track the car, I like knowing that my car has technology used in race cars... will I be able to exploit the potential?, maybe not, but it is still a cool feeling...
Old 12-01-2004, 06:11 PM
Guru_4_hire
Cruise-In V Veteran
Can someone tell me where the 3 galoon tank would go?
Old 12-01-2004, 06:58 PM
rwd
rwd's Avatar
If they're going to have two engines, then having a more expensive one with a dry sump is fine, but it's technological overkill for a street car. A wet sump 502 would do just as well for a lot less money.
To Wet Sump vs. Dry Sump
Quick Reply: [Z06] Wet Sump vs. Dry Sump
