[Z06] Magnesium Subframe
Magnesium Subframe
In case anyone is curious about magnesium - since the 2006 Z06 subframes
will be made using magnesium... Here's a "structural cradle" on
pages 10-16. It looks like it's either AZ91D, AM50A, or AM60A alloy.
Is a "structural cradle" a subframe??
http://www.eere.energy.gov/vehiclesa..._materials.pdf
Also:
http://autospeed.com/cms/article.html?&A=1103
http://www.findarticles.com/p/articl...09/ai_74034573
http://aiqnet.com/aml/ApplicationsMagnesiumHM-DR.pdf
Also:
Interesting reading, got part way through then the Government web site crashed.
In my mind, a subframe looks like a traditional automobile frame except for only a portion of the length of the car. It would bolt to a unibody car where the unibody is also only a portion of the car. I.E. early Cameros. This part looks like it bolts across the two side rails of the Vette connecting them structurally across.
George
George
Be sure to glance over that entire document. I'm amazed
to see aluminum MMCs being used for brake rotors. I would
have thought that the temperatures would get too hot.
Here's an old thread that is somewhat relevant:
http://forums.corvetteforum.com/showthread.php?t=864479
I can't wait for the GenV small-block. A HiPerf version could
use a magnesium block with titanium MMC parts. Give it the
latest iteration of the 3V heads along with central injection
GDI and you've got yourself a winner.
Also,
http://www.sae.org/servlets/productD...D=2004-01-0654
http://www.sae.org/servlets/techSess...ESSION_DETAILS
Notice the name Richard Osborne in the 2:00PM and 3:45PM sessions and the
list of names on Page 10 of the original document that I mentioned.
Also,
Originally Posted by Runge_Kutta
In case anyone is curious about magnesium - since the 2006 Z06 subframes will be made using magnesium...
Source?
I've posted this several times. Here it is again
Take a look at the 3:45 presentation. Notice that there is a special session
on the Corvette:
http://www.sae.org/servlets/techSess...&BYTRACK=HIGHP
on the Corvette:
Originally Posted by LS6v
The 3:45pm C6 Z06 presentation is gone.
The meeting is in 4+ months. The papers aren't usually submitted until
near the time of the meeting. You can buy the paper in May or June of
2005 if you wish. The point is that the title tells you most of what
you need to know. If you're not an engineer then the actual paper
will be of little value to you. The combination of knowing the title
to this presentation and having the very first link I gave above tells you
a bunch that you would otherwise not know. If it's worth anything,
one can get up to a 25% weight savings by moving from aluminum
to magnesium. From page 10, you get the feeling that the new magnesium
parts are going on all C6's but the title of the paper implies an
exclusivity. (Maybe we're talking about different parts?) They claim a 35%
weight loss.
By the way, take a look at SAE 970370:
http://www.sae.org/servlets/productD...PROD_CD=970370
The C5 parts are made of Aluminum Alloy A356-T6. Magensium is very
castable and I wonder if the new part isn't cheaper than the aluminum one.
I don't see a weight listed but those front and rear crossmembers are
big parts and likely weigh a bunch. I'd be surprised if you couldn't take
10 pounds out of each. The picture of the C5 crossmembers looks just like
the figure 2 on page 11 of the original link. Figure 3 may be the other
one (front or rear) but they use the phrase "job 1" which is a Ford expression.
Originally Posted by Lazerwolfe
Check out Rick's thread. It's mentioned towards the end.
Originally Posted by Rick
Remember those ugly wheels on the C5 that cost $3000.00 well they melted them down and are going to use them in part of the frame.
Thanks,
Speaking of lightweight materials ...
For anyone who wants to see where the future is for things like
aluminum, magnesium, titanium, carbon fiber, and MMCs:
http://www.eere.energy.gov/vehiclesa...research.shtml
http://www.eere.energy.gov/vehiclesa...ications.shtml
http://www.eere.energy.gov/vehiclesa...vt_alm04.shtml
You're going to have to work to learn something here:
[Titanium]
http://www.google.com/search?hl=en&l...tanium+FY+2003
[Magnesium]
http://www.google.com/search?hl=en&l...nesium+FY+2003
[Carbon Fiber]
http://www.google.com/search?hl=en&l...ber%22+FY+2003
[Aluminum]
http://www.google.com/search?hl=en&l...uminum+FY+2003
[Metal Matrix Composites - MMCs]
http://www.google.com/search?hl=en&l...df+MMC+FY+2003
[Titanium]
[Magnesium]
[Carbon Fiber]
[Aluminum]
FYI: Next generation (2005/6) BMW 3 in-line 6 will have a composite Al/Mg block with a Mg cased transmission.
FYI: Aluminum brake rotors will have a much bigger problem with stress than heat. Aero grade Al can be made to take the heat, but Al alloys are just a bit to ductile. And a bit difficult to keep thickness variations with in specifications.
That's why cast-iron is still king. It's not just price.
Anyway, the future for brake rotors belongs to ceramic composites, IMO
Thanks for all the cool links!
