[ZR1] Two ZR1s, Three Drivers, 45 Quarter-mile Passes—Our Report
#201
Jschlinder "Gets it". The supercharged engine is every bit as affected by air density, as an NA engine. The supercharger is a simple air pump that is "geared" to the engine's crank shaft. It rotates at a speed that is mechanically "fixed" to the crank shaft, and determined by pulley ratios. Hence, less dense air going into the charger = less dense air coming out.
A supercharged engine will loose power with a gain in elevation at the same rate as an NW engine; 3%/1000'.
If you take a look at most of the 1/4 mile correction calculators that correct to sea level for a given DA, they give separate results for NA and FI engines with the FI results always closer to the actual.
#203
Night Owl for life
Received 3,246 Likes
#204
1 Post
Then there is humidity.
The ZR1 supercharger does have a relief valve that is set to 10.5 psi (not 100% sure on the setting). One of its purposes is to keep the boost pressure constant even in different atmospheric conditions, so for this supercharger it is more than just pulley size limiting the boost. So if you are running in very dense air it won't let it over overboost.
#205
I think the theory there is that the valve is always relieving while at sea level and closes more as you gain altitude to maintain pressure. I would guess that at some point in altitude gain you would start losing boost pressure.
#207
I always enjoy reading about these track outings, you guys always share info and run well. Racerns = Neil? We met a number of years ago.
I get what Jamie was saying, in fact none of the comments about DA versus traction are really contradictory in the thread. I remember taking a OT car and running 10.008@133mph with a 1.38 and on slicks, and the car started getting loose. The next time I tried to run that 9.9x it got colder and I had to get out of it mid track. There is that fine line.
I'd love to see what a ZR1 would do in this circles hands with long cooldowns, and I'd put a fan on the engine too. The not quite 132mph hot lapping and limited number of runs makes me think that 135mph is possible!
#208
Very nice writeup, and amazing performance for a factory stock car.
I calculated the 0-60 mph times for the runs, and the best was 3.13 seconds. The calculation spreadsheet was posted here a while ago. This 0-60 time puts the ZR1 well into the class of 'super-exotics'. Way to go!
#209
Hey John that is me. I think we met up at the drag strip near Rockford for a mfba get together. That may have been the last time I took my camaro down a drag strip. When was that '01 or '02? I only lived out in IL for a few years.
#211
Pro Mechanic
I believe that the "blow off valve" in the ZR1's supercharger has been proven to NOT function as a wastegate, as you're implying.
In all the correction calculators I've used and seen (a lot since I live at 7000' and take corrections seriously), I've NEVER seen one that had a separate factor for "FI engines"...and how could one? All FI engines are different. Doesn't matter though, b/c all mechanically driven FI engines have no means by which to "know" or compensate for changing elevation.
#212
No. That is correct math/theory for turbos w/wastgates up to the point that the turbo is maxed out (though you didn't account for added heat with elevation), but it is dead wrong for "gear" driven supercharged motors. The supercharger absolutely can not maintain "10psi boost" as the DA decreases. And how could it? The only way possible would be to have a CVT driving the 'charger, and have the CVT control module reference Absolute pressure, and "shift" the supercharger drive ratio according to DA. That supercharger drive system does not exist on the ZR1.
The same bypass valve is used to control boost at high engine speeds, but in that instance, pressure acting on the other side of the actuator opens the vavle. The pressure is controlled by a solenoid operated by the LS9's engine control module (ECM). When boost reaches 10.5 psi, the ECM energizes the solenoid and the actuator opens the valve, venting manifold pressure to the blower intake limiting boost
#213
Pro Mechanic
Here is the description of how the the bypass valve controls boost of the superchager from this article http://www.corvetteactioncenter.com/..._pursuit3.html
The point of the BOV in this engine as stated in the article, is to improve efficiency. Having the compressor 'over boost', or pump more air than required at or near sea level (where most people live), only to bleed off some of that boost through a BOV....that's incredibly INEFFICIENT. No way would GM design something to operate that way, in these times. Not to mention the added heat such a design would generate!
Here is one that does. http://www.dragtimes.com/da-density-...calculator.php I don't have the source but I remember that when they apply the standard NHRA correction factors to turbo cars the use 50% of the factor.
EDIT: I looked at that Dragtimes calculator. I don't buy it. First I stand behind what I say about supercharger operation. Second, I've ran 12.89 @111 in my box-stock, base LS2 C6 in Salt Lake City (4200' elevation). Plugging in the data, THAT calculator is claiming that my car (box stock LS2) will run 11.67 @122 at sea level. Not only is that "calculated result" up-in-the-night, but it's not even close to consistent w/any other calculator that I've used. The calculators that I've used have been verified for accuracy, by me, running the "calculated number" at a lower elevation venue. I'll never run 11.67 in my car. That calculator is "Busted".
As a mechanic of over 20 years, I absolutely would like to hear this persons input.
#214
Pro Mechanic
Does your car have a boost gauge? If so, go pull the vacuum line off that vacuum pot, plug the line, and go rip on it and tells us what peak boost you see, and at what RPM. My guess is that you MIGHT see 11 lbs at or right before the redline.
#217
#218
#220
