[ZR1] Suspension control knob problem for all ZR1s...
#42
To those who replied to my earlier post. I do have a ZR1 (2011). And I understand the concern. But I don't see it as a problem. And apparently neither does GM. However, that does not mean they won't make a change if enough customers complain.
The DIC tells me what I need to know when using one of the PTM modes. I don't HAVE to see the text on the dial.
Some of you might try not let inconsequential things bother you. The car still runs and drives fine. But above all, it's safe. As long as you keep your eyes on the road where they belong and not looking at a dial on the center console.
#43
_"SCOTT"_
The response and stance you've taken seems like something GM may say to avoid responsibility of correcting the issue described. I think that at the very least, consumers should get what they paid for...nothing more, nothing less.
#44
You've got dashboard lights that "you don't have to see" because you have HUD...but you don't expect them to go black when you use your headlights in manual mode, do you?
It would seem to me that being such an inconsequential thing, it would be relatively easy to reprogram and implement a fix for those that want it to work...
#45
GM is punishing you for turning your headlights on during the day.
#46
The Consigliere
Received 5,444 Likes
Don't flame; I'm just curious as to others' perspectives.
Since the DIC reports what settings your in, what is the issue? You just look at the DIC when controlling the ****? Am I missing something?
#47
Something else GM overlooked that drives me nuts. Why doesn't the red light for the lock stay lit so I know my doors are locked. I have it set to auto lock but it's just dumb if you don't have that feature turned on. I've read a few times on here that people were at the track and didn't realize their doors weren't locked and their knee or elbow opened the door through a turn.
#48
_"SCOTT"_
You cannot see what mode you're in unless you're in comp mode.The DIC only indicates the PTM (comp) modes (1 thru 5), it does not indicate either tour or sport modes.
The DIC only indicates PTM (comp) modes.
#49
The Consigliere
Excellent question...
There's no way of knowing what mode you're in for sport/tour with any manual headlight option during the daytime.
Yeah, good point.
The car defaults to tour mode on start-up. Toggle the **** to the right and you're in Sport.
#50
Received 3,803 Likes
"Ask Tadge" Producer
#51
The Consigliere
Yup. Just checked mine. You're right.
My bad.
My bad.
#54
It's a toggle switch. If you want to be in Tour, then select left again. If you were already in Tour, it won't make a difference. If you were in Sport, congratulations, you're now in the mode you want to be in. If you have to look down to know what mode you're in, it shouldn't matter anyways, should it? Driving down the highway, I find the difference imperceptible.
#55
Further I discovered yesterday that while the illumination on the button remains on when the lights turn on automatically due to darkness, while illumination turns off when the headlights turn on automatically due to wipers been on..
#56
You are making an argument for the sake of making an argument. There are certainly ways around it, and yes it is not a debilitating issue. Still though for $100k + Car this crap makes no sense.
#57
I disagree that it's a problem. I also disagree that it's "crap." It's functionality that is inconvenient to a minority of drivers. There's no need to form a lynch mob. If your biggest problem of the day is that your MSRC **** light turns off when you turn the headlights while it's bright out, you're doing alright.
BTW are you Greek (Μολων Λαβε)...
#58
_"SCOTT"_
I can see that this is not a problem for you and this is fine. What I cannot understand is what is your problem with us having a problem with it. The function makes no sense the way it is now. I found this because I was worried that my control module was fried (as some members have found out, when the lights on their buttons where acting up).
"ZR1 out of box failure"
Now to irvbulldogs72, although this may seen to be a non-issue for you, it does tie itself to the suspension control system which IMO should be completely correct rather than "almost, kinda, sorta, correct except for..."
Not sure if you're following me here but it really should be just an update on the programming. Unfortunately that really isn't up to me or you to say, I would prefer that a qualified GM engineer look into the programming issue to make sure that it's "the only" problem with the program...If so, GREAT!!! Give me a recall notice to go to a dealer for the update, and for those that choose not to that's fine too.
#59
As you know Vas, my suspension control module had to be replaced from the day my car came out of Bowling Green. That was certainly an integral part of the ZR1's suspension. The issue was tied directly into the faulty operation of the control **** which is how I found the problem existed. (no lights in any mode was the problem)
I could not have said it better!
