C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Can ZR1 brake rotors be turned?
Old 06-01-2013, 09:30 AM
KC ZR1
8th Gear
KC ZR1's Avatar
Default Can ZR1 brake rotors be turned?
Looking at new rotors for 2009 ZR1. OEM- Best price I'm finding is around
$1600 per rotor. Is it possible to turn these rotors once? What is the minimum width I can safely go on the rotor before I should consider changing? Already changed the pads once and just bought new OEM pads that will be due soon.
Old 06-01-2013, 09:49 AM
racerns
racerns's Avatar
No they can't be turned and you go by weight to determine if they need to be replaced not thickness.
Old 06-01-2013, 09:53 AM
KC ZR1
8th Gear
KC ZR1's Avatar
Any idea on the weight? $6000+ is pretty heavy for rotors
Old 06-01-2013, 09:58 AM
whatcop?
whatcop?'s Avatar
Location: Daytona Beach/ Atlanta---- Good Ol' Florida Boy/ Georgia
Contact the user richierich on here and he has really good prices. If I'm correct they should be stamped with the weight you can take them down to. How many miles are on the car? Why do you feel they need to be replaced?
Old 06-01-2013, 12:23 PM
jvp
Support Corvetteforum!
jvp's Avatar
Received 3,791 Likes on 1,140 Posts
"Ask Tadge" Producer
Originally Posted by KC ZR1
Looking at new rotors for 2009 ZR1. OEM- Best price I'm finding is around $1600 per rotor.
You're not going to find prices much lower than that. Maybe a couple of hundred dollars here or there. These aren't cheap rotors by any stretch, but they'll last a lot longer than you think.
Never turn rotors! Never turn rotors! Never turn rotors! Repeat after me:
NEVER TURN ROTORS!
Turning a steel rotor reduces the material on it, which then reduces its thermal capacity. One of the rotor's jobs is to try to absorb heat away from the pads and then vent it off into the interior of the wheel. When you turn a steel rotor, you make it much harder for the rotor to do so. And you weaken it.
NEVER TURN ROTORS!
Now, specifically for the ZR1's carbon ceramics: unless you have a diamond-tipped lathe, you're not going to be able to turn them properly. And, even then, you'll just destroy them anyway. They're as hard as a rock, but also very brittle. If you attempt to remove material from their surface, you'll render them useless.
Well since we've established that you shouldn't turn these rotors, the minimum thickness no longer matters (it is, interestingly enough, engraved on the rotor's hub). These rotors evaporate from the inside out. Proper testing of them includes:
  1. Removing them from the car
  2. Scrubbing them with a hose and car-wash soap (and that's all!)
  3. Letting them dry
  4. Weighing them to make sure they're above their minimum weight
Like their thickness, their minimum weight is engraved on the hub. But they need to be as clean as possible before doing so, because excess brake dust from the pads will throw the measurement off.
Are you tracking this car? Why are you going through pads so quickly? Those of us tracking them have cycled through a few sets already, but the rotors are holding up fine. If you're tracking the car regularly but are only on your 2nd set of pads, then your rotors are almost assuredly fine.
Old 06-01-2013, 01:41 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
NEVER TURN ROTORS!
NEVER TURN ROTORS!
  3. Letting them dry
Old 06-01-2013, 02:30 PM
JUSTAC6
JUSTAC6's Avatar
baller price tag for a baller status car....
Old 06-01-2013, 03:25 PM
KC ZR1
8th Gear
KC ZR1's Avatar
Thanks for the info the car is tracked in Czech Republic. The mechanics there don't see that kind of car very often so the information you share on this forum is invaluable.
Old 06-01-2013, 06:16 PM
OnPoint
The Consigliere
OnPoint's Avatar
Received 5,432 Likes on 2,268 Posts
Cool to see these ZRs being enjoyed in other parts of the world.
I agree with the above - if you're only on your second set of pads, your rotors likely still plenty of life left in them.
Old 06-01-2013, 06:39 PM
timmyZ06
timmyZ06's Avatar
Originally Posted by onpoint
cool to see these zrs being enjoyed in other parts of the world.
i agree!
Old 06-01-2013, 10:14 PM
QUIKAG
QUIKAG's Avatar
I think word is the rotors will last 4-5 pad changes on average.
Old 06-01-2013, 11:26 PM
vette ruminator
vette ruminator's Avatar
Location: Deerfield, Illinois Turn On, Turn In, Track Out
I got about 72 track sessions out of my first set of front rotors. Here's some detailed info:
http://forums.corvetteforum.com/c6-c...e-my-data.html
I added cooling ducts and we'll see if this extends the life further.
Old 06-04-2013, 10:38 AM
jcosta79
jcosta79's Avatar
NEVER TURN ROTORS!
NEVER TURN ROTORS!
So what you're saying is that I should never turn rotors?
Old 06-04-2013, 10:42 AM
jvp
jvp's Avatar
That's about the sum of it, yes.
Old 06-04-2013, 11:41 AM
911/Q45
911/Q45's Avatar
You're always way too subtle Jas!
Old 06-04-2013, 12:02 PM
jvp
jvp's Avatar
Subtlety (n)
The art of using the lighter sledge hammer.
Old 06-04-2013, 02:27 PM
3LZZ06
_"SCOTT"_
3LZZ06's Avatar
I think he's just saying that so that you'll try it....
Let us know how you make out.
To Can ZR1 brake rotors be turned?
Old 06-04-2013, 07:58 PM
05dsom
05dsom's Avatar
went to Mosport this weekend for eight- 30 minute track sessions...lots of fun no problems-car was amazing.....but then the dreaded steering wheel vibration at 75-80 mph on the drive home...rotors out of balance?
had the chevy dealer do a factory spec alignment the week prior to tracking it because of pull to the left and I hadn't driven that speed since the alignment.
any thoughts? factory warranty on the brembo discs if they are out of balance?
Old 06-04-2013, 08:30 PM
QUIKAG
QUIKAG's Avatar
Check rubber accumulation in the wheels first.
Old 06-04-2013, 09:35 PM
vette ruminator
I have had the same thing. I think as the rotors lose mass I do notice that the vibration can rear it's ugly head. I am not sure this is a problem that can be completely solved.
This is assuming that the usual suspects like pickup on the inside or outside of the tires and rims or loss of a balancing weight have been excluded.
Maybe as you track more and the rotors lose more mass it may get better...
Quick Reply: [ZR1] Can ZR1 brake rotors be turned?
