[ZR1] Weld RTS Wheel Fitment & Traction issues
I have a bolt on ZR1 making almost 700whp and 700wtq, running stock wheels and 335/25/20 MT Street SS and have problems getting traction in 1st gear.
We decided to run 17x11 weld rts in the rear for extra sidewall and 18x5 in front to improve overall acceleration and unsprung mass. The front rim won't fit like they do on the c6 z06, so instead of grinding the calipers, we just order spacers and wheels studs and will try once its received.
For the rear, I ordered the C6 Weld RTS rims because we are installing C6 brakes. Tires are 315/35/17 MT ET Street SS.
I want to ask if anyone tried this setup and will it hold up 1st gear rolls from 40mph? Or shall we switch to M&H 325/45/17?
Also, are the 315 too narrow for the zr1 fenders on the c6 wheels? Will it make a difference if get the z06
If you want a tire to dead hook on the street use the MT Pro. Had these on my 1200 HP Supra and they WILL hook. Downside they last like 2 months if that , they will get you killed in the rain lol.
I would run a 17x11 C6Z fitment with a 315/35/17 ET Street R
Thanks I don't think them make them for 17x11 rims.. Are they radials or bias ply?
Damn ingot the base c6 wheels cause of the base c6 brakes.. I might either change to C6z or add spacers.. How does et sreet r compare to m&h? Is 28 inch too much for a 700whp car? Mainly straight line roll race. Sorry just got too many questions I'd like to know
This is my zr1 full bolt on aswell i just did the 17x11 rts with a 315/35/17 hoosier dr2 and they grab on pretty good from a first gear roll still spins a bit but its goin waiting on the local track to have a track day and actually try them out on a prept track and a good burn out and just hope they hook im sure it will be fine
28" is probably too tall for a 700whp car with 3.42 gears and an M6.
did you shave your rear calipers or change them??
