[ZR1] Timing chain removal
Hi guys just starting to make my gp tuning camshaft swap and want to know If i have to remove the oil pan to pull off the oil pump and change the timing chain. thanks for your Help.
Nobody know If i only have to unbolt the 4 oil pump Bolt and Take off the pump or its better to remove the oil pan or just loose the Bolt on the oil pan. Thanks
maximedx (04-28-2017)
