★WTT Brand New 3000+ HP Twin Turbo methanol engine/fuel/ignition for C6 Z06
****Looking to trade for a VERY clean low milage silver, black, or atomic orange C6 Z06 only. Mods are ok.***
This stuff is all brand new. Twin turbo 598" promod/outlaw 10.5/ drag radial engine. This engine with fuel system, MSD mag ignition, fuel injection and turbos is right at $70k and its all new.
Engine details:
All aluminum Twin turbo 598" engine. Built by one of the best in the business, Robin Stackpole of RS Peformance. Engine is new and has only been run on dyno to set oil pressure. Engine is setup for methanol and is new, no surprises or work out parts.
-Brodix block
-Brodix big duke CNC heads
-GRP aluminum rods
-Diamond pistons
-Total seal rings
-Lunati pro crank
-custom Sheetmetal/ cast intake, very trick!!
-fuel rails and cnc fuel rail mounts (3 per side)
--Wilson throttle body
-Moroso external oil pump, pan, and mandrel
-moroso oil heater
-ATI balancer
-Jesel rockers, lifters, and belt drive
-Smith brothers pushrods
-bullet cam
-clark copper head gaskets
-polished sheetmetal valve covers
-PSI valve springs
-MSD crank trigger
-MSD distributor
-Waterman cam drive fuel pump and bracket
-8 precision turbo 550lb fuel injectors
-8 precision turbo 160lb fuel injectors
-cam sensor
-Bigstuff 3 fuel injection and wiring harness (lightly used)
-fuel injection has datalogging, racepak CAN, and 16 injector driver
-MSD 8147 points box and 8132 tach adapter (still in boxes)
-MSD 8142 (still in box)
-Custom black anodized MSD promag 44 with wolferacecraft bracket
-new Precision turbo gt55-88 turbos
-wastegates
-Jerry Bickel Racecars front motor plate
Engine details:
-Brodix block
-GRP aluminum rods
-Diamond pistons
-Total seal rings
-Lunati pro crank
-moroso oil heater
-ATI balancer
-bullet cam
-PSI valve springs
-MSD crank trigger
-MSD distributor
-cam sensor
-wastegates
