<<< FS: Fully Built Arctic Vette 1000hp! >>>
Resulted in 921whp,
MOD LIST
YSI Supercharger
Flip Drive 6 Rib Conversion
A&A 3.25 pulley 8 Rib blower / OD Crank Pulley
A&A Newly Updated Bracket 8 rib
A&A Filter
A&A Ram Air Intake and Radiator Cover
ALKY Dual nozzle kit
Firecore50 Wires 8.5mm Promod
Meziere WP330N Water Pump
FSP Stage 1 Fuel
Injector Dynamics 1000
Big Cam 235/247 115lsa
Brian Tooley Drivetrain kit
Trunion kit
Superglide Transmission Fully built by Century
Transmission Cooler and Fan
Z51 Oil Cooler
PATC Torque Converter 2800 Stall
Blk Anodized Alternator 270 amp
Kooks Headers- Coated and Wrapped
Kooks X pipe
Innovators West 10% Overdrive Crank Pulley 8 Rib
PLX DM6 SM AFR2 Sensor Kit Combo
Baer Big Brake Kit 6P 14" all around in Arctic White
Solid Motor Mounts
Solid Transmission Mounts
Dewitts Radiator
D3PE Dual Fan & Shroud Kit
Akropovic ZR1 Exhaust w Carbon Fiber Tips
MSD Dynaforce Starter
Casper Cooling Fan Mod
CBM Fuel Rails and CBM Fuel Gauge
Variant Silicone Radiator Hoses
Black Euro Spec Headlights
Rear Onyx Tail Lights
Oracle Side Markers Tinted Black
ZR1 Front Lip
ZR1 Extended Rear Spoiler
ZR1 Extended Rear Lower Valence
Bride Gias Low Max Seats in Carbon Fiber
Lloyds Corvette Racing Luxe Mats
Carbon Fiber Center Console
Carbon Fiber Steering Wheel
Custom Valve Cover Set 'Corvette Racing' in Arctic White built by CBM
American Car Craft Stainless Door Sills with Carbon Fiber Corvette Lettering
Toyo R888, 265/35/19 & 315/30/20
Carbon Fiber Shark Bar
Pyrotect 5 point harnesses
Lambert Fog light Air Cooling Vents
Engine build done by Fountain Race Engines!
416ci, 10:1 Compression Ratio, Estimated 950HP Motor Rating: 1200HP
Platinum Manley Pistons - Manley Performance Platinum 4.070" Bore/4.000" Stroke Pistons with 9130 Pin Upgrade, Total Seal AP Ring Set
Manley H-Beam Connecting Rods
Manley 4.000" Stroke Pro Series Crankshaft
Clevite MS2199 Main Bearings Clevite Rod Bearings
Melling Select High Volume Oil Pump, LSx Katech C5R Timing Chain
ARP 04 Chevy LS1 Pro-Series 12pt Head Stud Kit
GM Oil Pan Gasket, LSx Wet Sump
GM Balancer Bolt, All LSx Wet Sump GM Rear Main Seal, LSx
GM Rear Timing Cover Gasket, All LSx GM Front Timing Cover, Seal, All LSx GM Front Timing Cover, Gasket, All LSx GM Exhaust Manifold Gasket, All LSx GM Waterpump Gasket, All LSx
GM LS9 Head Gasket (Single)
GM LS7 Lifter Set
Joe Gibbs Break-In Oil , Includes 10 Qts + 2x Filters GM Dexcool Coolant (Gallon)
Fountain Race Engines - Machine Work
Align Hone Mains, Check Big & Little Ends Connecting Rods, Check & Set Main/Rod Bearing Clearance, File-Fit Piston Ring Set, Assemble Pistons to Connecting Rods, Weigh Rotating Assembly, Balance Crankshaft, Assemble Rotating Assembly, Assemble Top End Package - Including Degree Camshaft, Timing Chain, Oil Pump.
Price asking $60,000 ( trolls move on ) I have over 60k in build receipts and well over 100k in car! If you think you can build this car or similar for less go ahead and price out your build and exterior/interior modifications, it wont come close. Go to any stealership and you will spend 60k plus just for a base C7 with like 350whp, just sayin.
Engine & Trans have maybe 4000 miles.. Rest of car 59,000 miles, garaged entire life of car.
Will come with a brand new set of 4 front and rear R888s and a spare matching drag pack of 2 rear F14 Forgestars with Brand New Toyo R888s mounted brand new.
MOD LIST
YSI Supercharger
A&A Filter
FSP Stage 1 Fuel
Trunion kit
Z51 Oil Cooler
Kooks X pipe
Solid Motor Mounts
Dewitts Radiator
ZR1 Front Lip
GM LS7 Lifter Set
This isnt a blog thread only post if serious otherwise dont waste my time thanks. Firm on price..
Please dont bother making an offer if you arent serious with cash in hand, I am not in a rush to sell and would rather keep it than take a loss. No more flakes please only serious buyers. Please do not blog off topic only buyers post questions, free friendly non haterade bumps welcome tks.
Please NO TRADES... Thanks
ttt
Arctic Vette (11-24-2016)
Arctic Vette (02-21-2016)
Ttt
Lots of interested buyers....... No funds tho..lol
Arctic Vette (03-09-2016)
Top
Ttt
8Obo
