C6 Corvettes for Sale Private Classifieds, Used C6 Corvettes For Sale, and Modified or Stock Corvettes
FS: 2007 ZO6 Built 450ci 11.9cr RHS Block, Mast heads, Rpm L7 TR6060
Old 09-19-2017, 01:53 PM
Daniel Hoffele
Daniel Hoffele's Avatar
Default 07 ZO6 Fully Built 450ci, RHS Block, Mast heads, Rpm L7 TR6060, 30k+ in parts
Engine:
450CI 11.9CR 700+hp RHS LS Aluminum Race Block, Callies compstar forged crank with Arp main studs and Callies H-beam forged rods with Arp 2000 rod bolts, Wiseco 4.165 -2.8cc forged pistons, Clevette bearings throughout, Ls9 oil pump, Cam Motion custom grind cam 248/266 .650/630 112+3, Comp timing set for rhs block, Comp hdy link bar lifters, Comp hi-tech chromemoly push rods, oem rockers with comp trunion upgrade, ARP head studs for 6 bolt heads, Mast Motorsports black label 305cc ls7 6 bolt heads pac springs, stainless valves, 70cc chamber, billet rocker rails, Fast LSXR 102 intake full ported, Nick Williams 102mm intake, Holley billet fuel rails, LS9 injectors, MSD plugs, oem coils, ATI balancer, Vararam ram air intake, Pfat motor mounts
Clutch:
Monster stage 3 single disc with light weight 18lb flywheel and remote bleeder.
Transmission:
RPM Level 7 TR6060 with ZO6 gear ratios and cryogenic treated
Exhaust:
Stainlessworks 2" LT headers with catless mid pipes, Corsa catback
Cooling:
Dewitts radiator with upgraded spal fans, 160 degree t-stat
Wheels/Tires:
Nitto invos stock size 3/4tred left, oem wheels that have been powder coated black with red pin strip
Body:
has had 3m clear bra since day 1 on the front and sides, it does have very few little rock chips else where that you can hardly see paint 8.5/10, Carbon Fiber hood plus i still have the stock one thats a 9/10. 5% window tint all around
Interior: 1
00%stock cept loyds floor mats, has HUD and bose NAV, no cracks tears or scratches anywhere 9.2/10
30K+ in parts alone ive put into this build. Brand new fully built engine and transmission and all bolton's have less than 1000 miles cept the corsa catback car makes 585/544 at the wheels and is still very steetable and comfortable crusing down the hwy with this big cam.
Has plenty of torque thought out the rpm range. Body has 50XXX miles on it, everything works as it should with no issues. The only reson im selling is to get more involed with offroading and travel. Im asking 45K might be willing to do some trading with cash on top
All work was done by Wes Choate @Sho-me speed in Ozarks, mo.
Can text or call any time 417-496-4337 Dann
Email Danngto@gmail.com
Old 09-19-2017, 03:02 PM
Daniel Hoffele
224xLC Dynamometer features a 24" knurled, precision balanced drum, Eddy Current Load Absorption Unit, 2000-hp measurement capacity and a max speed of 200 mph
Old 09-19-2017, 09:08 PM
Daniel Hoffele
Heres a short idle clip
Old 09-21-2017, 09:22 PM
Daniel Hoffele
Bump
Old 09-21-2017, 11:15 PM
cseaman
cseaman's Avatar
Would you be interested in selling the CF hood? I am fairly local, but went to school in Springfield, so I can always find an excuse to head down, ha ha.
Old 09-22-2017, 06:37 PM
Daniel Hoffele
Not as of right now, ill let u know if i do
Old 09-22-2017, 09:58 PM
Eshoremd
Eshoremd's Avatar
2023 C5 of the Year Finalist - Modified
I feel like I owe you a few dollars just for listening to that clip.
Daniel Hoffele (09-23-2017)
Old 09-24-2017, 12:29 PM
Daniel Hoffele
Well consider reasonable offers
Old 09-24-2017, 10:25 PM
cseaman
cseaman's Avatar
If you're accepting offers, you could probably put the stock hood back on and make some $$....
Old 09-24-2017, 10:44 PM
Daniel Hoffele
Well the stock hood is sitting in the garage
Old 09-26-2017, 06:57 PM
Daniel Hoffele
bump
Old 09-28-2017, 03:47 PM
Daniel Hoffele
Old 10-01-2017, 12:19 PM
Daniel Hoffele
bump
Old 10-04-2017, 11:24 AM
Daniel Hoffele
Bump
Old 10-04-2017, 06:28 PM
940CACC
940CACC's Avatar
GLWS...what hood is that?
Old 10-05-2017, 09:50 AM
Daniel Hoffele
RK Sport Carbon Fiber Violator Supercharger Hood
Old 10-05-2017, 01:36 PM
Tarheels1
Tarheels1's Avatar
Default Wow
[QUOTE=Daniel Hoffele;1595704577]
Wow what a beauty!!! Wish I had $45K!
Daniel Hoffele (10-05-2017)
To 2007 ZO6 Built 450ci 11.9cr RHS Block, Mast heads, Rpm L7 TR6060
Old 10-09-2017, 12:08 PM
Daniel Hoffele
Bump
Old 10-10-2017, 10:17 AM
iwantaz06now
iwantaz06now's Avatar
Amazing mods...Do you feel like the car is tuned very conservative or the dyno reads low? I feel like such a naughty setup should yield well over 600+rwhp
Old 10-10-2017, 11:22 AM
Daniel Hoffele
It does have a conservative tune
And from what ive seen it this dyno reads low i had a sc 408 ci camaro that put down 535 on texas speed dyno then brought it to this dyno and it put down 485 after some tuning he got it up to 520. I asked Wes the other day what hci zo6 are putting down he said around 530-550hp and 480-510tq so dyno depending it will hit well over 600 they all read a bit different some more than others
Quick Reply: FS: 2007 ZO6 Built 450ci 11.9cr RHS Block, Mast heads, Rpm L7 TR6060
