WTT: Built 2008 Subaru STI, Roll Bar, Bucket Seat, The works
I know this is a long shot but I figured I'd post it here to see if there may be any takers. I'm looking for anyone who may be interested in a straight trade for a C6 base, GS or Z.
Location - Lovettsville, VA
Mileage - 72XXX (Will only go up slightly while the motor is broken in and tuned)
After waiting 9 months to get the motor built and replaced I just feel as though I've lost interest in the Subaru so I'm looking to move on to another platform as a track dedicated car. As you can see by browsing the modification list no expense was spared in assembling this car and once tuned it should be a very fun street/track car. The car is currently at IAG getting the new motor assembled and installed but it is capable of 500+WHP easily. I should have the car back in my possession this weekend and I will take as many photos as possible.
If you want a ride I will take you for a test ride, you can drive it once you pay for it. NO JOYRIDES
The car currently has 72XXX miles on it and the motor has ZERO.
I know what the KBB value is, I know what the mods are worth and I know what I will accept. Asking price is $26K, I still owe money on it so we will have to transfer the title when you pay for the car.
Updated Parts List:
Engine
Fuel Setup
Turbo Setup
Transmission/Differential
Suspension/Brakes
Interior/Exterior:
The flat hood is brand new paint, the only major defect on the exterior is just behind the passenger, rear door where the OEM paint protection film peeled off a bit of paint while it was being removed. Pics up tonight.
Updated Parts List:
Engine
- IAG Stage 2 Shortblock(Closed Deck)
- Manley Forged 100mm Pistons
- IAG H Beam Rods
- ARP2000 Rod Bolts
- ACL Bearings
- Closed Deck
- IAG Built Heads
- BC Valvesprings
- GSC +1MM Intake and Exhaust Valves
- Valve Job
- Vapor Hone
- ATI Super Damper
- Cobb Accessport V3
- Cobb Oil Cap
- Cobb 4 Bar Map Sensor
- Grimmspeed EBCS
- IAG Competition AOS
- IWire Engine Harness
- Killer B Oil Pan
- Killer B Oil Pickup
- Killer B Oil Baffle
- KSTech 19mm Phenolic Spacers
- KSTech 1/2" Throttle Body Spacer
- Koyo Radiator
- Mach V Header Heatshield
- Mach V Air Pump Delete
- Magnaflow 3" Catback(Extra 4" Vibrant Race Muffler Welded In)
- MAPerformance EL Header
- Perrin Radiator Shroud
- TIC Idler Pulleys
- Torque Solution TGV Deletes
- Torque Solutions Motor Mounts
- Visconti Tuning Wideband Harness(Rear o2)
Fuel Setup
- AEM 320lph E85 Fuel Pump
- Cobb Flex Fuel Sensor
- Cobb Fuel Pressure Sensor
- ETS 3” FMIC
- ID1300
- Radium Auto FPR
Turbo Setup
- Perrin Rotated GTX3076R Kit
- Garrett GT3076 .82 Turbine Housing
- 3" Vibrant GESI UHO Catalytic Converter Welded In, V-Band Connections with removable test pipe
- Tial MV-R 44mm EWG
- Tial Q BOV
- Cobb Short Shifter
- Comp Stage 4 Sprung 6 Puck Clutch
- Comp Clutch Steel Flywheel
- Goodridge Clutch Line
- Group N Transmission Mount
- Kartboy Shifter Bushings
- TIC Trans Crossmember Bushings
- Whiteline Differential Inserts
Suspension/Brakes
- Autopower Race Roll Bar(Not Installed Yet)
- ARP Extended Wheel Studs
- Cusco Center Floor Brace
- Cusco Power Steering Rack Brace
- Cusco Rear Lower Control Arms
- Cusco Rear Member Power Brace
- Cusco Rear Side Member Power Brace
- Cusco Type 2 Lower Arm Bar
- Enkei NT03+M 18x9.5 +40
- Hankook RS4 265/35/18
- Hawk HPS Brake Pads(Street)
- Carbotech AX6 Brake Pads(Track)
- ITS Pedal Support Bracket
- Motorsports Tech Custom 10mm Wheel Spacers(Hub rings machined into them, hub centric to car and wheel)
- Feal 441 Coilovers
- Kartboy Endlinks
- Perrin Brake Master Cylinder Brace
- P&L High Pressure PS Hose
- Redhorse Stainless Braided Lower Pressure PS Hose
- Stoptech Slotted Rotors
- Stoptech Stainless Braided Brake Lines
- Soul Function Trunk Kit(Not installed yet)
- Whiteline Anti Lift Kit
- Whiteline Roll Center Kit
- Whiteline Front Control Arm Bushings
- Whiteline Power Steering Rack Bushings
- Whiteline Rear Subframe Inserts
- Whiteline 24mm Sway Bars Front and Rear
- Whiteline Rear Sway Reinforcement
Interior/Exterior:
- 2011-2014 Facelift
- AEM X Series UEGO Wideband
- AEM Oil Temp Gauge
- AEM Oil Pressure Gauge
- Aeroflow Dynamics Type 4 Splitter
- Auto-Blip Rev Match Downshift Module
- Billet Workz Teardrop Shift ****(Black)
- Billet Workz Reverse Lock Out(Red)
- Billet Workz Arctic Camo Shift Boot
- Billet Workz Arctic Camo Ebrake Boot
- Billet Workz Ebrake Button(Red)
- Custom Vinyl Tail light Red Outs
- Dialed Mounts Accessport Defroster Mount
- FastWRX Bumper Quick Release
- FastWRX STI License Plate Trim Piece
- Grimmspeed License Plate Relocation
- JDMFY STI Grill Badge(Black)
- JDMFY STI Trunk Badge(Black)
- OMP Champ R Driver Seat
- Buddy Club Super Low Seat Rail
- RallyArmour Mud Flaps
- R205 Fender Badges
- SMY Clustermaker Dual Gauge Pod
- SolidMods Vent Pod
- Sony XAV-AX100 Head Unit w/ Apple Car Play
- "STi Style" Front Lip
- Painted OEM Headlight Shrouds/High Beam Buckets
- Morimoto X-VF 7440 Reverse Lights
SteveDoten (07-17-2019)
The oem horns are extremely high pitched and quiet but I did it because the oem horn was to thick to clear my IC so they were a $60 solution to that problem.
I had a 06 sti before my vettes...loved that car. this one is slick!
