NOS install on LS3: Wiring Diagram question
Hey im planning on installing a TNT kit on my Ls3, but as for the electrical part im not too sure what wires to use. I purchased all switches and relays and im ready for the install but on the diagram it doesnt specify what type of wire. I have a 16 gauge 12v black wire?? can I use that to connect to all the parts or is it diff. gauge and voltage for different things? would someone mind guiding me in the correct direction . Thanks!
Collections Hold
16 gauge will be fine on your low amp side of the relays IE: trigger for relays, arming switches to relays, small purge noids etc. Any item of greater amp draw i would use the 14 gauge wire IE: n2o noids, bottle heater etc. If you have any doubts at all, use the heavier gauge wire as a safety precaution. Now, on ti using all the same colored wire, well you certainly can; however, if you ever need to do diagnostics and/or add another item you can become confused very easily. So, I would rec using colored coded wire and keep a schematic of what you used for future reference. Here are a couple wiring diagrams that may give insight into wiring up a nitrous system, as they will pretty much cover all goodies we may use. By the way, if you, or anyone else, has a good general C6 schematic that I could host with these other diagrams, that would be a great help to others, thanks.
Nitrous Wiring Diagrams and info
Robert
Robert
