C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
What's Next???
Old Jun 23, 2009 | 07:22 AM
vinnie12345's Avatar
vinnie12345
Default What's Next???
I have an 05 C6 with;
P-series Procharger 8lbs boost
Kooks long tube 1 7/8 headers 3" x-pipe no cats and corsa ends
Meth kit
After my tune the stats are:
570 WHP & 521 WTQ
What is the next mods for me to gain HP & TQ??? I'd like to see 700WHP & TQ without blowing her up.....
Thx guys!!!
Old Jun 23, 2009 | 08:07 AM
Jutskin's Avatar
Jutskin
"without blowing her up....."
Is it your stock bottom end?
You have a good tuner?
05 tranny and diff? There are limitations with 05's, I learned that fast.
Good luck.
Old Jun 23, 2009 | 08:59 AM
vinnie12345
Every thing else is stock.... Except for clutch and fly wheel, SPEC Stage 3+ rated for 900lbs TQ. My tuner is Gil Nevarez at NPR in Las Vegas..
Old Jun 23, 2009 | 07:11 PM
NandoZ06's Avatar
NandoZ06
Whats the compression on that engine? Lower the compression, by forging pistons,push rods,crank,cam,internals, maybe you can use the same block without upgrading it.Sum cheat juice also
Old Jun 23, 2009 | 07:42 PM
Mr.Big's Avatar
Mr.Big
blower grind cam with springs to suit, and heads if you want to help the cause... CNC LS3 heads and intake would be great for your goal...
and pulley her for more boost...
also if your running a single nozzle on the methanol injection system, upgrade to a dual nozzle set up...
as for tranny and rear end, that one is just a crap shoot... been there done that, got the trophy and the T shirt...
Old Aug 20, 2009 | 11:51 AM
Taylor@DallasPerformance's Avatar
0Taylor@DallasPerformance
Former Vendor
One of our stage 2 blower grinds, our Big Mouth Air Filter, and pulley down for 10 psi should get you over 6XX in this heat.
Old Aug 20, 2009 | 03:48 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Originally Posted by vinnie12345
Who's a good tuner in Las vegas???
Use Jeff--TPE
Old Aug 20, 2009 | 04:05 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
You should be able to pulley down and up the meth on your setup and gain quite a bit. I would look into the Dallas Performance big mouth intake for the Procharger kit as well.
To What's Next???
