C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
NOS WOT switch
Old Mar 5, 2010 | 05:13 PM
ccs1's Avatar
ccs1
Default NOS WOT switch
What type of WOT switch are you using?
Old Mar 5, 2010 | 10:12 PM
ccs1's Avatar
ccs1
Guys I need help, I now have a WOT switch installed at the petal. Do any of you have a better application?
Old Mar 5, 2010 | 10:54 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
google tps c5 switch and you'll find some that tie into the tps wiring
all the links i've found are to other forums so i can't post them
Last edited by schpenxel; Mar 5, 2010 at 10:56 PM. Reason: or at least that's how i THINK they work..could be wrong
Old Mar 6, 2010 | 12:18 PM
chsmith112's Avatar
chsmith112
Just ask Dave at Nitrous Outlet he is very knowledgable!!
Old Mar 6, 2010 | 03:56 PM
Nasty C6's Avatar
Nasty C6
The livernois tps,it's wired to the tps. #f on the plug,color of wire is yellow.
Old Mar 6, 2010 | 04:27 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
I've used both and like the pedal switch better. If you want a tps electronic switch let me know, I'll sell cheap.
Old Mar 6, 2010 | 08:15 PM
ccs1's Avatar
ccs1
Why do you like the pedal switch better? I had a hard time installing it to be accurate. Maybe its because I don't know what I'm doing.
Old Mar 6, 2010 | 09:43 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
It's mechanical and you can tell when it is working by the sound. Very easy to install, Check for pictures. It is installed with the same little bracket that holds the solnoids, only one bolt. Bend the bracket for adjustments.
To NOS WOT switch
