C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E-Force 1590 Kit
Old Sep 6, 2010 | 05:17 PM
62Jeff's Avatar
62Jeff
Originally Posted by CSIXX1
Forgot you had a LS2. But you are running the smaller LS-2 kit with the smaller pulley and you didn't change the pump in the tank or use a BAP correct?
Yes that is correct. My only caveat is that my LS-2 starts with 405 HP, and the LS-3 starts with 430, and I don't know how much difference that 25 HP delta makes to the stress on the fuel system.
CSIXX1's Avatar
CSIXX1
Originally Posted by Motorhead-47
Your question isn't easy to answer. I've personally never seen a stock pump fail from a BAP. Are they out there?....probably but I have not seen one. Does it shorten the life of the pump?...I'm sure it does to some degree but if installed correctly the BAP only raises the voltage when you exceed the 3-4 psi at the switch. How much time do you really think you spend above 3 psi in daily driving? The few failures I've seen have come from the car blowing the fuel pump fuse under the hood in setups where the BAP was installed in the rear fender area at the chassis to pump connector. The solution to that possible failure is a $70.00 Racetronix dedicated fuel pump harness to avoid overloading the pump circuit.
There are hundreds of Vettes running around with BAPs without issue. It's a good alternative to those that don't want to replace the pump.
There isn't much if any cost savings if you are doing the work yourself but if you are paying someone else to swap the pump the BAP value is clear. Query the two high volume centri installers out there and get their spin on this one. They've seen a ton of cars.
Thanks for all of your input it's greatly appreciated.
Old Sep 6, 2010 | 05:19 PM
CSIXX1's Avatar
CSIXX1
Makes sense. Thanks again for your input it's greatly appreciated.
Old Sep 6, 2010 | 05:25 PM
Motorhead-47's Avatar
Motorhead-47
Found this post with a few negative fews on BAP use.... http://forums.corvetteforum.com/c6-f...fuel-pump.html
Old Sep 6, 2010 | 06:31 PM
CSIXX1's Avatar
CSIXX1
Thanks again for the info. Got another question I know you have a M6 but does the e-force canned tune do anything with the transmission parameters for the A6?
Old Sep 6, 2010 | 07:10 PM
Motorhead-47
I can't help you with that one. I simply do not know. I'm "old school" and believe all real sports cars should have three pedals. That's a good question though and I'd say give Edelbrock a call and ask them or better yet....PM forum member/vendor " TJWONG " and ask him. He just recently wrapped up an LS3 A6 install.
Old Sep 8, 2010 | 10:52 PM
3 Z06ZR1's Avatar
3 Z06ZR1
I understand that and I understand how the BAP works it only ups the voltage under boost, but what are the chances that my stock pump could or would fail over time from the increased voltage and would there be any warning signs.
Also 62Jeff stated (Post #7) he is running the 1591 kit with out a BAP or swapping out the fuel pump. He stated his tuner said he had no fuel issues so the question is do you really need it if you use his example you could say no.
I'm new the FI world so I'm learning by asking questions.
They say that the BAP's do not damage or shorten your fuel pump life.
Old Sep 9, 2010 | 04:18 AM
SpinMonster's Avatar
SpinMonster
Ainqik, Powerlabs and I all had pump failures from the BAP.
As to how often you go into boost when daily driving: I just had a kenne bell car here that also needed a fuel system because the BAP wasnt cutting it and that car's boost gauge showed 8 psi every time I pulled away from a stop light. This wasnt even getting on it. I added a parallel fuel system that came on when the car would hit 5psi with a Hobbs switch. I had an LED on the gauge pod and it lit up all the time in casual driving. That should give a hint of how often a BAP engages if it does so at 4psi.
The in tank pump cools from the fuel its in. If you go under 1/4 tank you can overheat the pump.
The MSD votage booster boosts in relation to the boost level rather than the off-on nature of the KB BAP. This may be better for centrif cars but the pos displacement s/c's will see boost and therefore voltage all the time.
As for there being 100's of these out there in use, you count failures to get a failure rate. As I see it, you can piece together a real fuel system for 600 bucks. A BAP costs 400. doing the install yourself will take 2 hours which is a lot less time than replacing a stock pump if it fails or an engine when you go lean under boost.
Dont shoot the messenger. Im not a BAP guy. The way I see it, a lot of kits wouldnt get sold if the BAP technology wasnt very good so all vendors are a bit biased in wanting it to work as advertised.
