C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
T trim or YSI
Old 09-30-2017, 05:51 PM
jaked4484
jaked4484's Avatar
Default What belt would I need?
Just wondering what belt I would need? I'm gonna have a similar setup.
Originally Posted by Mike Yeager@Eastcoast Performance
Hi, it really depends on your engine build...How many cube's..?? Do you have a Water/meth kit..?? What type of balancer are you running or going to run..??
We custom build dozens of SC Corvettes every year...we also sell & ship about every custom performance part available for the C5's & C6's...
You can make 12-13lbs of boost on a YSI with a 6-rib set up, and the correct belt..!!
Call me and I will be glad to help in anyway I can...
Old 10-10-2017, 01:04 AM
Lexicon
Lexicon's Avatar
See the 761 hp dyno at 11.5 lbs, 6500 rpm V3 8 rib A&A kit thread I posted. The stock heads and bottom end can't take much more. YSI would be of no use and less efficient. The V3 goes to 7050 rpm without being over spun but the ls2 engine probably can't handle it.
But...if you are building the bottom end the YSI may be the right fit.
I want to bump the rev limit up but need to have some conversations with A&A before I do.
Old 10-10-2017, 03:47 PM
croatbob
croatbob's Avatar
If your building an engine for it, strap a ysi on that bitch!
Old 10-10-2017, 11:21 PM
CRUSHAH
CRUSHAH's Avatar
Originally Posted by aTX427
Go with the Ysi. It is a great head unit. Remember, you can always run a restrictor plate until you are ready to turn up the boost.
^^This^^ Why do it twice??
Old 10-10-2017, 11:40 PM
C U IN REARVEIW
C U IN REARVEIW's Avatar
Originally Posted by Riggs
I just made 737whp with the T-Trim and 3.4 pulley on straight 101 octane last night, 17 degrees of timing.
Completely factory long block, stock heads/cam, etc.
Stock clutch!
Only fuel mod is a MSD BAP....
About to do the same
Old 10-14-2017, 02:29 AM
JKTURBOTA
JKTURBOTA's Avatar
I have made 768rwhp so far on a cammed ls3 with 8in balancer and 3.6 sc pulley. Still havent touched heads, intake, and havent even come close to reaching the max impeller speed. This is through a A6 also. I say if you want stay in the 750-850rwhp range the T trim will be perfect. Any higher then YSI
Old 10-14-2017, 09:48 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Ti Trim/1500 and be done. Easy 800rwhp which is where you want a vette. Past that just goes down hill quickly.
Quick Reply: T trim or YSI
