Finally going boosted ls3+D1sc
#41
Former Vendor
You actually have our D5 version... Same cam I made 811rwhp on with an otherwise stock LS3 and 12psi
#42
not touching the fuel system at all. for 700-750 rwhp you dont really need to with the ID850s.
As for the bap. for every 1 car that blowes up with the bap.. 50 are running 100% fine.. I know more cars that popped from a replacement fuel pump failure then the BAP failing. When the time comes and i do a fuel system, it will be an all out system.. The setup wasnt cheap.. but I really got it done for not a whole lot.
BTW.. if im not mistaken silver08z51 ran a BAP on stock fuel pump when he had his D1sc setup.... He can obviously correct me on this.
Did he not also blow his engine? But I hear you, it is a roll of the dice anyway you slice it. Let us know your final #'s and your impressions about you new found power!
#43
If i push 22# and pop the motor.. it's easy to say " ZOMG THE BAP BLEW MY MOTOR cos it couldnt keep up"
at my power level i dont need a $2500 fuel system, and with what this whole setup is costing me start to finish installed.. that would GREATLY increase my total investment.. It wasnt cheap.. but it was far from a " baller expensive" setup..
#44
sam told me about that.. im pretty sure im not going to crank it up that high.. dont have the fuel to keep up with that kinda power demand
Thanks for all the great parts again!
What kinda fuel system did the 811 rwhp camaro have? F1A right?
#45
Former Vendor
The ID850's have nothing to do with your fuel supply (fuel pump). Your ID850's are will have better drivability if used with the excellent data avilable from Injector Dynamics but other wise it is no different than a standard 80# injector in terms of fuel delivery at WOT. Just for reference: 850cc = 80.88#
There is very good reason for running a proper fuel system as suggested. However very few Corvette guys step up at your anticipated power level since it is tolerable. The methanol system is the only way I feel good about saying that. But if you don't have the tune scaled correctly and the meth fails you will loose the motor because you will not have enough base fuel to support the power (just in general with this sort of combo).
You are right we had his setup the same way as yours. BAP, 80's and methanol. It is not the ideal way by any means if I had a blank checkbook to work with but it is a great combo for the money.
#46
Former Vendor
oh nice.. i thought it was the D1X.. whats the difference?
We have made 5 or 6 small changes to that cam to get what we wanted out of it. The D1 was the first version.
Larger pump and BAP, modified rails and methanol. F1A with 5.00" pulley and stock balancer. Basically the same blower as a D1SC but with the more aggressive transmission step up ratio in the blower to run larger pulley at same impeller speed.
I guess I should make a thread about it.
#47
There is very good reason for running a proper fuel system as suggested. However very few Corvettes guys step up at your anticipated power level since it is tolerable. The methanol system is the only way I feel good about saying that. If you don't have the tune scaled correctly and the meth fails you will loose the motor because you will not have enough base fuel to support the power.
That being said, if i had a blank check, i wouldnt be doing a D1, i would be doing a Built 434 with a f2 or some nastey twins..
The d1 will keep me happy in the C team till i can ford to forge the motor and do fuel. Even then im not looking for 1200 rwhp, Because then the drive train falls apart.. eventually when the sun and the moon align, if the car in its final form makes 850-900 rwhp i will be happy.. for now 700-750 will be plenty zippy enough.
#48
#49
Former Vendor
Yeah I wish he did one of our blower cams so he didn't have to run that much boost to make the power. Ohh well he is bigger and more powerful now!
That is a REALLY fun power level. You will love it.
#50
once the car is done, and i can drive it around abit, i will come get the clutch. I want to replace it rather then wait for it to go out.
#52
I was originally going to have the mesh in the front nose of the car removed because it was silver and stood out WAY to much, but after seeing several FMICS ( and the one i had on my supra) beat to death from rocks hitting it, i decided to leave my mesh grill and have my installer Sam paint it black. So it will keep larger rocks out of the fmic.
#55
#60
the old windshield washer res is my meth tank.
not going to drop the gas tank. its easy mode on your c5.. but WORLDS more complicated on an 08.. Stock fuel for now.
