VS402 Stroker A&A YSI Build near completion
#43
So that is an m10 and a tiny 2nd nozzle. Unless that pump is running some serious pressure that is not much meth for a car trying to max out a ysi. I'd guess like 780rwhp trying to keep it safe. The guys making 850+ on pump+meth use lots of alky. 50/50 is great, but you need twice the volume.
Most snow kits I have seen are crap, but I suppose you can spec it however you like.
#44
#46
Good luck with finishing off the rest of the build. Watching the previous one was painful.
#47
Half of it is water. That will help prevent detonation, but it won't help much in making power. You likely need 2 m10 nozzles running at least 2/3 meth to safely make somewhere in the 850-950 range with 93 in the tank. This is an educated guess, but it is pretty educated....lol
#48
Former Vendor
#49
634 rwhp
604 tq
#50
Location: Greater Detroit Metro MI, when I'm not travelling.
"Best" is a very relative term. It would be "Best" to ditch the whole system, have a functional windshield washer, less weight from not having that pump up front, and not entrusting your engine to another system which can and does fail. It is also best to not have to worry about running out of Methanol during a long trip. I've ran out 3 times so far. I can easily go through 2 gallons of methanol for every 1000 miles driven and that is a typical weekend drive for me.
HAVING SAID THAT... Pure methanol will always make more power, period. So if "best" = most power you should be running that.
#51
Hi John,
#52
I think 50/50 is best for preventing detonation assuming enough octane. The water helps prevent spark knock. Snow only rates their pumps for 50/50. The issue is that you need twice as much volume as you do meth only to make the same power assuming you need the octane.
The numbers you made could be made w/o meth though. Are you running a 6-rib? I had assumed you had an 8" balancer.
#53
The best argument I've heard for 100% meth was from Julio. It has to do with the temp at which meth turns to gas which is under the typical FI intake temp. So as soon as it hits the intake charge it phase changes and will distribute more evenly whereas water will still be in liquid form and the droplets will not distribute as evenly.
#54
#55
Regardless of all this debate you are going to need a certain effective octane to be able to throw enough timing at this setup to make power safely.
#56
Seems kinda strange for anything to puddle under boost. I ran a 50/50 mix activating progressively from 2-3psi maxing out an m10 nozzle for 2 years making over 700rwhp on a stock ls6 with zero issues.
