Pinning the Crank
Pinning the Crank
Hi All,
While looking at the instructions from Edelbrock, the procedure to pinning the crank requires the use of some specialist tools:
DT-47731 Transmission Oil Cooler Quick Disconnect Tool
J-42188 Ball Joint Seperator
J-42385 A Flywheel Holding tool
How do you guys go about getting these parts or is there a different way to get around without using these parts? I know some shops (from searching google) have their own way to pin the crank but they don't disclose their procedure.
I'm going to be removing the radiator to install a dewitts so hopefully that should give me some more room. I intend to take a ton of pics and post them in the How to do section.
Any ideas would be gratefully appreciated
Peace
Steve
Peace
Steve
silver_viper_tb (05-04-2016)
Yep - funny Edelbrock says that actually. All FI kits require pinning. But my A&A kit did not require special tools to do it. Don't remember needing a hammer either...but did need a band-aid or too. You know it's not right if you haven't made your blood sacrifice yet....
There is a much easier way to gain access to the crank to pin it than what is in the Edelbrock instructions. The other method involves loosening the 4 engine cradle nuts and allowing the cradle to hang loose and then removing the two engine motor mount nuts (all are accessed from below) and lifting the motor with a floor jack. It will cut hours off of your install time!
I talked about it a few months back in this thread http://forums.corvetteforum.com/1575847339-post37.html
Instructions with pictures start on step #56 here http://www.magnacharger.com/pdf/manu...ntercooled.pdf
MUCH EASIER AND A LOT LESS MESS!
Sure you can. I swapped my cam by lowering the cradle.
A guy could always argue that any time you touch anything related to the front suspension you should have the alignment checked but in this case, just loosening those 4 cradle nuts and then retightening should have virtually no impact on your alignment specs.
What I described above (just loosening the cradle nuts and lifting the engine) only gets you a couple of inches.
When I pinned the crank on my 06 vert I lowered the sub frame/cradle and raised the LS2 per Motorheads procedure. While I had room to pin the crank, I don't believe I would have been able to get a puller on the crank pully or have been able to remove it without pulling the steering rack. The cradle was lowered approx 6/8 of an inch (nuts left in place at the end of their bolt threads), and the engine raised high enough that I had to remove the Oil Pressure Sending Unit so it wouldn't contact the firewall. When installing the E-Force I made a mental note of this fact in the event I would want to upgrade my cam in the future. How far were you able to lower your cradle? I loosened all four bolts of the cradle and the motor mounts and had to pry the cradle/sub-frame away from the frame in order to obtain room for the crank pinning process.
Harbor Freight has a 4lb hammer with a very stubby 7" handle that works great for these type of tweaks
Item # 98258 "4lb Drilling Hammer"...a whopping $12.99
