***ETMCs LINE OF FI CAMS, WITH IDLE CLIPS***
Former Vendor
Ok guys. Its always a question. what cam should i use/who has FI cams/ whats the idle sound like/what gains do i get. well here is a little thread im going to start with our three FI cams we offer and one of our NO2 cams. If you want any other info on the( other than exact specs) just ask, ill be happy to answer.
FIRST
our stg 1 cam
we Made this cam for our guys who want a sleeper stealth cam. not a ton of lope but great results. usually 40-50 RWHP on same boost levels
IDLE CLIP:
COUPLE OF RESULTS CARS:
THE NEW RIPPER CAM
Cam was made for the guy who wants a little more lope but not to over the top.
STG 2 cam:
his cam was made as a perfect all around cam. works great for FI as this is what we came up with it for, but as you can tell buy a few NA camaros here too, that is does great NA also!
IDLE CLIP THROUGH MAGNAFLOW
DYNO RESULTS:
Nitrous cam:
IDLE:
dyno run in f body
30+ HP gain over others nitrous cam, just NA!
this cam in also in the world record holder Fastest stock bottom end GTO with a 10.2 ET 1/4 mile run with full interior and stock gearing.
FIRST
our stg 1 cam
IDLE CLIP:
THE NEW RIPPER CAM
STG 2 cam:
DYNO RESULTS:
Nitrous cam:
IDLE:
dyno run in f body
