My UPP Twin Turbo thread
#243
St. Jude Donor '08-'11
How are you liking your boost controller? There is a race coming up on Dec. 19, thinking about putting a little methanol on her and maybe upping the boost a little for it...
#247
St. Jude Donor '08-'09
below is my dyno with my A&A kit and full bolt-ons. can someone say holy tq?
didn't do any tuning. will probably strap it down on a mustang to keep the turbos spool'd. on the street with the aem tru boost set the same i make 14psi all day.
all in all, im happy i was able to make some clean pulls and drive it home...
-Carl
#249
-Carl
BJK
#257
You're ballsy for running that thing at 0.86 lambda. I don't even run NA cars that lean. This is in reference to the screen shots from the track.
#258
my buddy runs his at 12.5 then over 8psi to 11.7afr over 14psi gets 11.0. he swears it makes the turbo come on faster...
i might do the same.. set pe to 12.5, then use the boost pe to bring in more fuel.. but ive heard, the boost pe is slow to bring in the fuel.
-Carl
#259
I do that but it's kind of a waste. I hardly ever see PE without BE. I have heard the 3rd gen PCMs had trouble relying on BE but I have not seen any problems with my E40.
