C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
The twin turbo Z06 build from Hell finally done!!
Old 10-04-2011, 12:51 PM
  #41
DSteck
DSteck's Avatar
Power is probably dropping off because of timing getting pulled, and the engine just can't move the air through efficiently. That's why they tend to peak at 6000rpm. Mine does the same thing with super worked LS7 heads and a custom turbo cam. Boost could be dropping off too.
Old 10-04-2011, 05:31 PM
  #42
extremecorvette
extremecorvette's Avatar
Originally Posted by SinisterC6
Im interested in running an APS kit what sort of oil and coolant temps do you see? How have you liked driving the car?
I will have to let you know once I get it car picked up over the weekend.
Old 10-11-2011, 03:43 PM
  #43
0Taylor@DallasPerformance
Former Vendor
Taylor@DallasPerformance's Avatar
Power noses over for several reasons. The turbine on the APS kit is designed for a stock LS7 engine and lower boost levels (quick spool). They are small for a 454 cid engine with higher boost levels. The turbine chokes off the engine basically at higher pressures.
If you have a dyno log of the boost on the dyno it will show that the boost falls off with RPM as well.
We have some billet impellers for those turbos with new compressor covers that helps but will still have the same problem. We have done extensive porting on these APS turbine housings which help as well.
This combo would have been a better match with 427cid instead of 454cid. The larger engine esentially consumes all of the air that those turbos can effeciently produce early. What I mean is that your peak power would have been pushed up by running a smaller displacement engine.
You should also verify that your intakes are not collapsing. I have seen this a few times on the C6Z APS kit at higher boost levels.
Old 10-11-2011, 06:49 PM
  #44
extremecorvette
My motor is 72cc heads, 4.130" bore, 4.000" stroke, gasket 0.062" but need to check, and the JE pistons I will have to check on how many -cc they are but they are very close to being flat. I think the motor works out to be around 429cc. For some reason everyone has been thinking its a 454. I don't think I posted that.
You think the intake lifters might be collapsing at the higher RPMs? Thats funny you say that because I had to take my last lifters out because the motor wouldn't go past 6,000 rpm due to that fact. That is why I have morels in the car now.
Have you had anyone swap out the GT3582R - 714568 - 10 for anything lager and still work with the APS kit?
Old 10-11-2011, 06:57 PM
  #45
THECRAIGMEISTER
THECRAIGMEISTER's Avatar
You are going to need the M/T tires for sure. I ran the BFG 345 drag radials and they didn't hook at all. I tried everything. They didn't hook as well as my Nitto Invo street tires. I am running similar hp and tq. Good luck with the rest of your build. Hopefully you can get out and enjoy it soon!
Old 10-11-2011, 07:01 PM
  #46
BoosterClub
BoosterClub's Avatar
+100 those BFGs are absolute sh*t
Old 10-11-2011, 08:41 PM
  #47
extremecorvette
I really want the Nitto NTO5R but they don't have them in my rim size. But when I bought the tires the M/T was not out yet in a 18" rim 345 tire.
Old 10-11-2011, 09:30 PM
  #48
tjwong
Support Corvetteforum!
tjwong's Avatar
I think Taylor is refering to the inlet hoses or filters to the turbos. I to have seen silicone inlet hoses collapse on high or even mid boost levels. If the filter doesn't have the flow capacity or are clogged, I have seen hoses that will collapse at high RPM under the suction of the turbochargers.
Old 10-12-2011, 11:45 PM
  #49
extremecorvette
Look what I had made for my car, They look great!!!
Old 10-13-2011, 01:50 PM
  #50
Slo-Poc
Slo-Poc's Avatar
^^^^ omgoodness those are very nice.
Old 10-13-2011, 10:27 PM
  #51
Former Vendor
Thats a 429cid roughly.
Your lifters are not the problem here. The turbo is out of steam.
We have a direct replacement setup that upgrades that turbo to a billet compressor wheel and new compressor covers that are machined to work exactly like the APS system.
Old 10-15-2011, 10:49 PM
  #52
extremecorvette
The new lifters did work out and the motor has no issues getting passed the 6,000 rpm any more.
What are the gains from the billet comperssor wheels and new compresser cover? Then last whats the cost?
Old 12-20-2011, 10:45 AM
  #53
extremecorvette
Pictures have been added in the 1st post of the car all cleaned up
Old 12-20-2011, 11:31 AM
  #54
0Bobby @ LG Motorsports
Former Vendor
Bobby @ LG Motorsports's Avatar
The inlets are not collapsing. When they collapse, you know it, and you see it, and it only occurs at 20+ psi. 800 rwhp isnt anywhere near 20 psi.
Also, boost will maintain a steady 16/18/20 psi, what ever you set it to. The turbos are starting to move out of their efficiency, thats all. The density of air, needed to keep 20 psi of boost at peak RPM is starting to decrease. IE, hot air. Its the nature of the beast. Big torque, instant boost on a stock engine, this is what it does when you turn up the wick.
Get it to pull clean to 7k, and you end up with a laggy setup, thats probably slower on the street, and less enjoyable to drive.
Old 12-20-2011, 12:40 PM
  #55
vrybad
vrybad's Avatar
Originally Posted by turbotuner20v
why does the torque (and hp) fall off so hard on the final run?
run 3 looks great though
I believe it is because that last run is out to 7000rpm, whereas the 3rd is to 6300.
The last run is still significantly higher than the 3rd, making ~860rwhp at 6300rpm vs ~800rw at the same rpm in run #3.
Nice results.
Old 12-20-2011, 02:41 PM
  #56
EdwardETraylorIII
EdwardETraylorIII's Avatar
That car should be cracking 1,000 RWHP on PUMP gas with that size engine and those turbos (and presumably the proper camshaft is in that engine given that so much work went into the engine).
Old 12-21-2011, 09:33 AM
  #57
palindrome1H
palindrome1H's Avatar
Great build! Congrats on a sweet setup! Very jealous!
To The twin turbo Z06 build from Hell finally done!!
Old 12-21-2011, 01:57 PM
  #58
extremecorvette
The cam is 232/226 622/608 114 4 degree advance built into the cam
Int open at 6 degrees close at 46 degrees
Exh open at 51 degrees close at -5 degrees
Old 12-21-2011, 04:22 PM
  #59
5 Liter Eater
5 Liter Eater's Avatar
St. Jude Donor '11
I like that cam.
Also the badges.
Old 12-21-2011, 07:08 PM
  #60
Detoxx03
Detoxx03's Avatar
Very nice car
Quick Reply: The twin turbo Z06 build from Hell finally done!!
