STOCK LS7 with 15+ lbs of boost..... NASTY
Former Vendor
Here's what a proper tune and the right combination with a stock untouched LS7 is capible of. None of the last three years of racing pass after pass could of ever happened if it wasn't for "Roadrebel". He is the mastermind behind the keyboard (and tech support at all hours) that took baby steps to get it to this point with ZERO failures of any sort. This pass was made at Indy at the LSX shoot-out in full street trim (like I ever drive it on the street ),we did NOT do any weight reduction at all. I hope to get it back to the track soon in good weather to knock the time down as this was not its best 60ft or MPH....
Almost makes me want an auto. But then I remember that I like shifting gears.
Does every auto conversion end up requiring a standalone controller, or is it possible to integrate the TCM into the system so HP Tuners can read it out and edit it? I wouldn't hold my breath for that, but it'd be cool. Awesome job either way.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
All the RPM cars performed fantastic over the weekend, on top of that they were helping others with trans problems get back on track.
A real class act group of guys.
(I know, I know, you already knew that..)
Former Vendor
Thanks Doug.... It was good seeing all you guys again except for Chris I will have to admit... when you were out there ***** footin around running low 9's in the Z06 I wanted to call you out for a grudge race ! Good thing I didn't cause then you put the hammer down and busted out that 8.78... Good times on and off the track all weekend.
Former Vendor
Former Vendor
Thanks for the Props Rodney!
But, truth be told I am only 1 cog in a machine that accomplished the goals we had this year. So congrats and props back to all the members of the RPM driveline Team.
Phil
Phil
That's moving out guys . Once again thanks for trying to find the parts for my trans, sometimes it just not in the cards.
