C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
100 shot on automatic transmission. what controllers you guys using?
Old 11-15-2011, 06:05 PM
VETTEPLAY
VETTEPLAY's Avatar
Default 100 shot on automatic transmission. what controllers you guys using?
I have a 2006 cammed, full bolt-on coupe with an automatic transmission. Ive bought the saftey accessories for my n20 kit but im against the wall on what controller to use to keep from tearing my automatic transmission up. Are you guys using regular controllers or are you using the progressive controllers? I would appreciate your advice and experience. Those with 100 shot on your automatic transmission had any issues or things you would have done differently? I read that the "sudden hit" is what is hard on the car and transmission so I figured I would bring it to you people that have experience. Thanks.
Old 11-15-2011, 09:20 PM
RICKEY BOBBY
RICKEY BOBBY's Avatar
The AMS is a nice piece of hardware you can't go wrong with there stuff ,
Old 11-15-2011, 09:24 PM
carlrx7
carlrx7's Avatar
St. Jude Donor '08-'09
if the ecu pulls the throttle back before each shift, a wot switch will work fine..
Old 11-15-2011, 10:10 PM
TRINIC5
TRINIC5's Avatar
100 shot on any auto is not a problem, just make sure you have a window switch for the motor safety, the window switch should be set to activate at over 3000rpm and shuts off at 6200rpm.
I had dual nitrous on my C5 which had a very weak transmission (4L60E) and was running 300shot of nitrous, 150 from 2500rpm and a second stage (another 150) after second gear and never damage my transmission.
I took a bolton C5 to 10.60et with nitrous and went 13.20 without nitrous.
Old 11-15-2011, 10:20 PM
VETTEPLAY
VETTEPLAY's Avatar
Thanks for the responses. Always better to hear from you guys that have been there done that. I was concerned about the actual shifts at WOT on nitrous and any potential damage.
Old 11-16-2011, 10:59 AM
White_06_A6_C6
White_06_A6_C6's Avatar
pm sent
To 100 shot on automatic transmission. what controllers you guys using?
Quick Reply: 100 shot on automatic transmission. what controllers you guys using?
