Adding 2nd IAT sensor for meth tuning and displaying value on Aeroforce gauge?
From what I understand, people are adding a second IAT sensor to their intercooler pipe to tune their meth setup. So it goes intercooler > MAF > meth nozzles > 2nd IAT sensor > throttle body.
Is there a certain type of sensor that needs to be used? Can this sensor be tied into an Aeroforce gauge to display IAT's real time w/ a LED trigger if IAT's go above a certain range?
I'd like to add something like this
http://www.aeroforcetech.com/products_sensors_temp.html
But I'm not sure if it can also be used to read IAT's for the meth tune.
Most just cut the wires and splice in a IAT plug (or get an adapter harness) and add the sensor after the maf, not in addition. Any of those listed should work.
ah, that makes sense... I was wondering how the tune factored in both IAT values. So you just cut the IAT wires that lead to the MAF and attach them to the generic aftermarket IAT sensor and it can use that instead.
All you need is a 3rd gen IAT sensor and break out harness. Pretty sure ECS has them.
The Aeroforce will read any IAT you use through the ALDL along with any other PIDs. But I would stick with the GM IAT as any one you put in will need to be recalibrated in the tune and you can find the cal from the 3rd gen IAT's from a 3rd gen tune file.
So you could set the interceptor up to alert you when Boost >~5# AND IAT > ~90. To do this you need to be running a 2 or 3 bar MAP which does not require a speed density tune. I plumb my wide band into the Aeroforce and have it alert me if Boost >3# AND AFR > 12.
As far as tuning the meth, set it up like you mentioned so the IAT sees the temp drop from the meth. Then either leave the high octane spark table where it is now (~15 degrees) and add timing via the IAT spark adder table when IAT is less then a certain amount (I think I start adding at ~80 degrees and only in the upper flow areas); or set the HO spark table to max timing and use the IAT spark adder table to take timing out when IAT's are higher than expected assuming the meth is flowing.
If I buy the ECS alky kit, it looks like I would get a GM 2 bar map sensor (same as what aeroforce sells). Could I tap into this for both the alky kit and the Aeroforce gauge?
And while I'm buying the kit from ECS I can confirm the IAT setup is included, or add it to my order. I would just need one of the signal regulators to send 0-5v from the IAT to the gauge I guess.
My plan is to run knock/timing pull and fuel pressure on one gauge, then boost and IAT on the other gauge. I have an AFX wideband already installed for a/f, but no warning light.
If I can get the IAT and map sensor through ECS though, all I need is the fuel pressure sensor.
No. The factory MAF has the IAT built in. There's no such thing as a direct replacement IAT in this setup. I mean you can copy the sensor calibration from a CTS-V file and stick it in your's. The LS1 sensors use totally different calibration scales and units that don't correlate exactly with newer PCM labels. I am also a perfectionist, and that's why I use the CTS-V sensor.
BJK
Is it 3/8 npt threaded?
Also, does anyone know if this is the splitter cable I need if using this cts-v sensor?
http://www.casperselectronics.com/st...oducts_id=1108
or this?
http://www.casperselectronics.com/st...oducts_id=1137
thanks
or this?
or this?
BJK
thanks
or this?
or this?
Former Vendor
