mast 305 ls7 heads vs mast 285 ls7 for boost??
I'm getting ready to order my heads but I am having a hard time choosing heads.I like the Mast 305 LS7 heads. I also have been looking at mast 285cc ls7 . Help me choose!
THE HEADS FOR LSX 427 cid BOOST ENGINE
F1R PROCHARGER WITH DALLAS PERFORMANCE COG DRIVE 20psi
Forced Induction like the biggest and best flowing heads, so get the 305.
What's the cfm flow on these heads does anyone know? I assume you can't go wrong with Inconels in there as well that's what I did.
Either way nice choice with the heads should work very well for you!!
Almost same set up but I have 305's on !
I realize this is an old thread, but i'm really interested in knowing what head would be best for the mentioned application
I have an F1R procharged 427 LSX with 40 teeth pulley which should be making around 22-23psi of boost with and Mast black label 305 heads. I am currently making around 930 whp.
I've been told by so many people that going with the smaller heads would generate more power but this just doesn't make any sense to me. On MAST's official website there are tables for flow data, when comparing the 285 with the 305 you notice that they both have the same exact flow rates!
The only difference between the two heads is the intake port volume.
The question remains, WILL I BE MAKING MORE POWER IF I SWITCH TO A SMALLER HEAD? IF SO, WHY?
I doubt it would change. You are only going to make the power your blower is putting out. Want more power, turn the blower faster.
Supremacy 1 car at a time
I used the 285 and now building a new engine with 305, if you're not going to increase your bore then 285 is enough for 427CID IMO but if there is 1% chance to go more then go a head for the 305. best of luck and hope to see numbers soon.
