Extreme Widebody TTi-X 427" transformation build thread
Former Vendor
St. Jude Donor '06 & '12
Hey All,
Over the last 6 or so months, I have taken on the task of building a ground up C6. We literally stripped the car to its bare frame, and built it up from there. We pretty much didn’t leave anything un touched.
We’re about a week away from firing it up, so I decided to share with you what we have done so far. We focused primarily on cleanliness, and reliability. However, we also focused on being different than all the other builds. This was by far our largest, and most in depth build. We took the car all the way to its frame, leaving only the dash in place.
The car started out as a 2005 Z51 that I bought off this forum from a rich 21y/o kid, who beat the **** out of the car. I have never seen such a disrespected vehicle before in my life. Within the first week of buying it, we had it torn down, and ready to start rebuilding.
Below, is a partial list of the stuff we have done.
Body:
Interior:
Suspension, Brakes, Wheels & Tires
Motor, Valvetrain & Drivetrain
Forced induction, Fuel, & Cooling:
Obviously, there is about a thousand other things that were done, but Im sure based on the pictures you get the idea. We also paid special attention to wiring and hoses. If we could hide them, we did so. Many of which we completely re-routed in order to make them disappear all together. It was our goal to make just the motor stand out. By painting the intake manifold, and using CF valve covers, the motor looks unbelievably clean.
Now for some pictures.
I will add more as I go, so stay tuned..You can also view my entire photobucket folder which shows all pictures to date.
Body:
- SS Vette Extreme Widebody Kit
- Z06 Front Fascia
- Carbon Fiber halo and targa
- House of Kolors Tangelo paint
- Carbon Fiber Violator hood
- SS Vettes 3” CF extreme spoiler
- SS Vettes CF side skirts and canards
Interior:
- DSV Curved steering wheel
- Color matched console and radio bezel
- 2012 seats w/Ebony leather, Dark Titanium Alcantara, & Titanium stitching
- Interior color change from Tan Cashmere to Ebony
- Complete coverage of Dynamat extreme sound deadening
- MGW shifter w/carbon fiber shift ball
- Pillar pod with E-boost 2, & AEM w/b
- Pfadt Inverted coilovers
- ZR1 swaybars
- Performance AFX two piece front & Rear rotors
- C6Z06 Brake calipers, powdercoated in Orange
- Stainless Steel Brake Lines
- Powdercoated lower control arms
- 360 Forged 3 piece concave wheels (20x13-R, 20x10-F, black anodized center w/gloss black outer)
- Nitto Invo tires 345/25/20-R, 285/25/20-F
- Poly control arm bushings
- Darton Sleeved (By Steve at RED) 427” turbo motor
- Callies Billet crank & rods, Diamond pistons, Total Seal gapless rings
- ARP main studs, Billet steel main girdle, Clevite bearings, etc etc
- LS7 heads (lightly worked over) , ceramic coated Ti Intake and Inconel exhaust valves
- Comp dual springs, comp pushrods, custom turbo cam, all the other bells ans whistles
- ARP ½” head studs, cometic .051 head gaskets, stock rockers, w/trunion upgrade
- C6 ZR1 transmission
- C6Z06 Diff w/300m shafts, upgraded clutches & springs
- Centerforce DYAD Twin Disc Clutch with their new "Light Metal" flywheel. (Dyno'd at 1400+lbtq)
- TTi-x Twin Turbo w/PTE 6265 billet turbos, .82ar turbonetics exhaust housings (our T4 kit is still being worked on)
- Champion motors 3” downpipe w/turbonetics wastegates
- Dewitts custom radiator w/ 2.5” core (different than the regular 2” core they normally sell)
- Spal dual fans
- Aeromotive stealth kit w/eliminator pump and pump control module
- -8 Teflon stainless braided line on both the feed & return
- custom shaved fuel rail (internals removed, feed holes opened, feed line removed, -8 and -6an bungs added)
- Aeromotive regulator, ID1000 injectors
Last edited by Jeff @ TPE; 02-15-2012 at 04:30 PM. Reason: Added manufacturer info
Former Vendor
Thanks!!
It'll look even better once my CF valve covers show up. Notice how I blacked out all of the accessories? I even had the brake m/c powdercoated satin black. The only one left to do is the throttlebody, and the fuel rail itself.
You cant tell, but my entire fuel system is hooked up. I made it so that you cant see ANY lines at all. Even the injector wires are routed under the intake.
Former Vendor
The downpipes in the pictures are the champion 3" ones.
We are modifying our T4 3" kit, and relocating them to the bottom because the drivers side wastegate only has about a 1/16th of an inch of clearance on both sides (between the valve covers and brake booster.) This is why they are currently not on the car.
Former Vendor
Its the only color for me...
We figured if we were going to do a shop car, the ONLY logical color was the colors of our shop (Black and Orange). I tried to keep it tastefull though. While it is a loud color, it is a marketing car. They are supposed to grab your attention.
Former Vendor
Heres a few more pics...
As you can see in the pictures, we sprayed the engine bay and frame gloss black. This REALLY sets off the motor. Mainly because it hides everything else, so all you see is the motor.
The coils DO have protection, and are completely safe & out of the elements. These photos just dont show the enclosure.
Wow, what a build. Keep the pics coming. Looks very clean thus far.
