442 LS7 Wet Nitrous
442 LS7 Wet Nitrous
on 442 LS7 engine
Zo6
how much can the fuel system can handle for Direct port Wet shot
i am talking about STOCK fuel system nothing changed
cheers
Zo6
cheers
I woudnt spray anything more than 100shot on 442ci LS7 but if you did Injectors and boost a pump for sure...
We sprayed 150shot on a couple of stock LS7 with injectors only, but 442 LS7 The block is already freaking thin
You do realize the extra cubes of the motor is due to an increase in the stroke of the crankshaft and the block maybe only be slightly overbored if at all. I know some people think the only way to make a motor bigger is to increase the bore size. I would imagine the motor in question has a 4.125 inch stroke crank vs the factory 4.00 inch stroke crank.
I've seen a fella spray a 200 shot on the stock system. Its a Z06 with a stock long block. It's through a plate system and he doesn't have a dedicated fuel system nor a boost a pump. I'm not saying you shouldtry this... But take it to your tuner and let him tell you when and if your running out of fuel.
