Meth Injector Location w/ Centri SC???
when I spoke to julio he recommended putting the nozzles as far from the throttle body as possible especially on dual nozzle kits. of course never spray it through the maf though
Received 1,194 Likes
St. Jude Donor '15
You can spray through the MAF if you aren't using it for air flow calcs. Some people just leave it there and use the IAT out of it and then you an spray through it no problem (but I guess at that point it's not really a MAF, lol)
I agree.. the further back the better. I have a new charge tube ordered that removes the MAF totally. I'm planning on putting the meth nozzle basically as far towards the intercooler as I can get it with the hoses I have to work with
I looked on their website and didn't see this, is it something they sell?
Yes. Call them and they can sell you whatever you want.
St. Jude Donor '15
Indeed.
They have with and without meth, with and without maf, ls2 and ls3 style. Letting everyone know their options isn't their strong suit
People depend on websites way too much. Hard to list everything on a website, especially for a small company. Phone or email works wonders.
Received 2,275 Likes
C4 of Year Winner (performance mods) 2019
A&A is the same way, they'll do whatever style inter-cooler to TB pipe you want, but they don't list them on their website. I think they probably make them as needed.
Or any local shop can whip one up in a few minutes. Doesn't take much at all to make one.
Platinum Supporting Vendor
For those looking at these pics, please note they all raised the washer tank up about an inch or two so the meth pump can be mounted high enough to not drag the ground.
Always good to have your question answered before you ask
#34
It's whatever comes with the newer A&A kits. I think it's a 4" bridge with a 4" to 3.5" coupler to neck down to the V3 Si.
#35
http://www.aacorvette.com/supercharg...roducts_id=336
#36
I do not feel comfortable taking the fender off my Corvette so the only option I have left is to mount the tank in the rear is this safe? I would not think there would be any fumes are anything else harmful but not sure.Thanks
#37
St. Jude Donor '15
You don't have to remove the fender for install. I think it was realcanuk that installed his by just removing one of the lower bolts on the fender and pulling it out enough to get access. You have to remove some plastic push pin things on the fender liner.. not hard at all.
Up to you.. some people do run the tank in the cargo area. If it's sealed then fumes should be non existent. I prefer it being on the outside of the car but cargo area can work too.
#38
The fender is easy to work around.
But if you get a trunk mounted tank, make sure and put a vent hose on it if it doesn't already come vented. Otherwise the tank won't flow meth freely if the tank is sealed.
