OFFICIAL A&A SUPERCHARGERS Q&A thread
#901
Platinum Supporting Vendor
The unit holds 3.8-4.0 oz of the V3 oil. You may get some misting or venting from top vent plug after recent oil change and hard driving, that is normal. Just wipe off any excess oil that mists out.
#902
The dipsticks are not that "accurate". Just make your own "full" mark on the stick if you want.
#903
I have an 08 ls3 with headers, ls9 cam, 3" exhaust. Getting ready to install Ti trim and was wondering if its ok to run 3.6 pulley on 93 octane until I get meth or do flex fuel down the road.
Will the 3.6 be too much boost for 93 only? Or would it be ok with low timing and rich a/f?
#904
#906
I keep eating belts even after having multiple shops align the pulleys/blower.
It has the secondary drive, kit was purchased one year ago. V7 vortech kit w/ IW 10%
#907
805-278-4107 shop
When it's all lined up correctly belts last for years.
#908
Hi,
i have broken the "reverse bolt" tensionner who should help to make the right tension on the belt.
Could you give me the spec of this special bolt to see if i can find it here in Europe ?
#909
It's a reverse thread short bolt that we have custom made. You can actually still adjust slide tensioner without that bolt on it. Just use a flat tip pry bar and you can pry against the smooth idler on the slider and get belt tight.
#911
#912
You guys ok with the fires? My cousin may lose his house in Carpenteria (4 miles south of there). The fire was less than 1/2 mile away. Just want to make sure all the A& people are doing good since they are in the danger zone (cue Kenny Logins music)
#913
We are okay where the shop is located, but had it make us nervous one day last week when it flared up again.
__________________
Thanks, Josh Dodson
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
• Facebook.com/AACorvette •
Thanks, Josh Dodson
OXNARD CA 93036
(805) 278-4107
#914
Scary. My cousins house is right off seacliff exit on Rincon rd south of carpenteria. Fire maps don't look good.
#916
#919
#920
When will the V3 head unit with the straight cut gears be available to purchase?
