OFFICIAL A&A SUPERCHARGERS Q&A thread - Page 48 - CorvetteForum - Chevrolet Corvette Forum Discussion
C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Old 05-21-2018, 01:02 AM
  #941
tobb14
CF Senior Member
tobb14's Avatar
Default 3.4 pulley
does anyone have the scoop on how to install a 3.4 pulley on A&A V3 supercharger kit. I've purchased the 3.4 with matching belt. I want to exchange them out this week but I don't know how to loosen up the tensioner to put the new belt on .
tobb14 is offline
Old 05-21-2018, 04:04 PM
  #942
Tech
CF Senior Member
Tech's Avatar
It will depend upon the version of the bracket you have. Look on YouTube for videos on how to replace the belt, that'll get you 90% of the way there. Replacing the pulley is pretty simple. Use a SMALL amount of anti-seize on the shaft and blue Loctite on the retaining bolt. Torque to 25-30 ft lbs per Vortech.
Tech is offline
Old 05-21-2018, 04:14 PM
  #943
[email protected]
Platinum Supporting Vendor
Josh@AandASuperchargers's Avatar
Sent him an email to help out, after he called into the office.
Josh@AandASuperchargers is offline
Old 05-27-2018, 12:58 AM
  #944
Sandworks
Junior Member
Does there happen to b a slight growl from the blower just off idle? When Iím in drive with brake alittle gas and it growls or vibrates, then goes away after another 1-200 rpm. Is it normal? Thanks
Sandworks is offline
Old 05-31-2018, 07:53 PM
  #945
LemansbluebyU
CF Senior Member
LemansbluebyU's Avatar
St. Jude Donor '12, '15
Default YSI boost question
So I had my car on the rollers today and all went well except that the boost would only go to 17psi at 5800 rpm and held steady there up to 7000 rpms. This an A&A kit with secondary drive and billet impellor YSI on a 427 cu in motor with mast heads, custom cam, holley high rise intake and American Racing ZO6 racing headers...... it has a 10% over driven crank pulley and a 2.75 s/c pulley. I'm thinking I have a boost leak somewhere but I've not yet looked over everything. I do have a dual nozzle alky kit on there which isn't being used and was wondering if maybe at that boost level boost is leaking past the nozzles, they are just in one of the silicone couplers and pretty wobbly. I also have an unrestricted 4" intake tube with an air filter on the end so I don't know if that is maybe restrictive. Just looking for opinions and maybe it anyone else has had a similar situation. Thanks for any help.
LemansbluebyU is offline
Old 06-13-2018, 04:27 PM
  #946
Cooter272
CF Member
My 05 only has about 35K miles on it and the harmonic balancer is still good. When installing a SC kit, are you guys replacing the balancer as a precautionary measure or leaving it alone if there is no wobble/play?
If replacing, what special tools are needed to get the job done? I have a long breaker bar and cheater pipe to get the bolt out. Does it take a puller to then remove the balancer or will it come off easily after the bolt is removed? What's the best way to keep the engine from rotating while removing or installing the bolt? I have an auto trans.
Thanks!
Cooter272 is offline
Old 06-13-2018, 04:48 PM
  #947
schpenxel
CF Senior Member
schpenxel's Avatar
St. Jude Donor '15
Def have to have a puller. There is a Chrysler one you can get on Amazon for $50 or so that works very well. Also need a tool to install the new balancer. It's a friction fit, not something you are going to get on otherwise.
schpenxel is online now
The Following User Says Thank You to schpenxel For This Useful Post:
[email protected] (06-14-2018)
Old 06-14-2018, 12:58 PM
  #948
Cooter272
CF Member
Thanks for the reply. Ive been reading up on it. Is this Powerbond HB good to use if I plan to supercharge in the future? Stock engine so probably going to stay around 525-550 RWHP.
Powerbond part # PB1117SS
The Following User Says Thank You to Cooter272 For This Useful Post:
Old 06-14-2018, 02:31 PM
  #949
schpenxel
CF Senior Member
schpenxel's Avatar
St. Jude Donor '15
This the one I'm running, had it on for 50K miles or so, no issues. I don't have any personal experience with the Powerbond so I don't want to anything good or bad
I'm sure Josh does though, maybe he can chime in
https://www.summitracing.com/parts/sum-c2501
Old 06-14-2018, 02:45 PM
  #950
[email protected]
The PB should be fine too.
Or these 2 are easy choices:
C2501 or TFS-19005
Old 06-15-2018, 07:32 PM
  #951
Cooter272
CF Member
Thanks for the help on the HB, guys.
Im still on the fence about self-installing my A&A kit. The car is not my daily driver so I can take me time doing it and I am pretty mechanically inclined but this will definitely be my biggest undertaking to date. Im the type of guy that likes having vehicles in the garage to work on, so this may be fun for me....just a bit intimidating I guess at first!
Old 06-16-2018, 05:58 PM
  #952
Mike's LS3
CF Senior Member
Mike's LS3's Avatar
I drove down from the Bay Area to A&A Corvette (Oxnard) and had them install/tune. They did and great job and the drive home was fun
Definitely replace the HB with other than oem, powerbond, ATI, etc.
Mike's LS3 is offline
Old 06-16-2018, 07:27 PM
  #953
Cooter272
CF Member
I thought about that but that's 5.5 hours each way 4 times, twice with a 2nd car so I have a ride home and back. Plus, I do like to tinker and work on my own vehicles....I guess I just need to man up and go for it hahaha.
Old 06-17-2018, 12:28 AM
  #954
tommypenguin
CF Senior Member
tommypenguin's Avatar
Just ordered replacement idlers from a&a and noticed the new ones are metal and the old ones are plastic. My old ones are .15 inches larger in diameter. Any concerns over running the new idlers impacting boost or belt length?
tommypenguin is online now
Old 06-17-2018, 05:56 PM
  #955
tommypenguin
CF Senior Member
Called a&a, they said should be no issues swapping to the new idlers.
Old 06-29-2018, 06:01 PM
  #956
Sergio8A
CF Senior Member
Sergio8A's Avatar
Hey Andy/josh,
do do you guys still offer head unit trade ins /upgrades ? Looking to upgrade my V3SI to a T trim.
Sergio8A is offline
Old 06-29-2018, 07:12 PM
  #957
[email protected]
Originally Posted by Sergio8A View Post
Hey Andy/josh,
Yes we do. Give us a call at the shop to discuss trade in options and headunits.
805-278-4107
Old 07-02-2018, 02:16 AM
  #958
camarokidz28
CF Senior Member
Support Corvetteforum!
I have the old bracket design. I was thinking about replacing the tensioner and belt as I am fighting some belt slip (690whp, V3 Si, 3.6 inch pulley). Should I be thinking about going to the new bracket design entirely instead? I'm definitely going to have to call and see about upgrading the Si also, so that could be a factor in the decision. I'm using the single pump external for fuel at the moment, so I'd possibly need to go dual pump and go e85 instead of 93.
Is there much to gain going to the Ti? Will a Ti make 800 whp or would it be better to go ysi with a smaller pulley? At what point is an 8 rib and/or secondary drive necessary?
camarokidz28 is offline
Old 07-03-2018, 11:45 AM
  #959
Cooter272
CF Member
Instructions say not all cars need the water pump housing ground down. Mine kind of looks like the belt would clear without grinding and it also doesnt seem to have as much excess metal as the one on the instructions. What do ya'll think?
In regards to grinding down the water pump housing, are we needing to grind down just that upper corner or does the grind need to follow all the way down the face? See area outlined in red.
Thanks!
Old 07-03-2018, 01:52 PM
  #960
[email protected]
Thanks!
Grind the dark area of your red shade. Should be fine just need a tiny air gap and it's good.
Quick Reply: OFFICIAL A&A SUPERCHARGERS Q&A thread
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
