Which balancer for LS2 with A&A kit?
I'm having an issue where my newly installed A&A bracket is hitting the balancer / crank pulley. It looks like the balancer is further out than the rest of the pullies and the bolt is tight so I assume it is bad. With all the reports of the OEM balancer being problematic, can anyone suggest a good aftermarket unit. I want to ensure I get one that someone has used with an A&A kit so I don't have to worry about clearance issues.
I just ordered this one yesterday. Same diameter as stock and SFI approved.
$189
http://www.summitracing.com/parts/TFS-19005/
$189
I have an A&A kit on a LS2, I put a Professional Products 90033 - Professional Products PowerForce Plus Harmonic Damper. Got it from Speed Inc. Same size as stock, but won't come apart like the stock piece. Worked fine with the kit.
