Who loves injecting meth!
I am almost convinced that meth is the way to go for cooler iat's, safety of the motor, sustained performance, etc. I need some help guys.
I would like to hear from those running meth how there real world experience is with it? (Particularlily anyone running a tvs2300 bower with it, but by no means limited to that) Some say its an annoyance, some say its the best thing ever and completely necessary on higher horsepower builds...
What are your thoughts on your meth systems? Both pros and cons? Is there maintenance involved? I am considering ECS's alky control kit. Anyone have any issues? Are there any important things to be mindful of when running meth (how long the meth can sit in the windshield tank for when the car is not in use, pump/system maintenace, avoiding clogs, etc.)
Any regrets?
Is it really necessary for about 650 rwhp and roughly 10lbs of boost?
Thanks guys, I am trying to learn as much as I can from everyone as I plan my mods
Any regrets?
I do! I do! It's like race gas on demand. Show me another way to make >950 RWHP (User_Name) at the wheel on pump gas. OK, E85 but that comes with it's own set of complications.
09 JSB, I am now Offically a White Trash Meth Head!!! A&A Supercharger 10#'s of Whoop-@$$, Alky Control Meth Kit, LS7 Exhaust, Pfadt Adjustable Shocks and Circle D 3400 Stall!!!! I beg people to roll race me!! Ordering my 305/35/19 M/T Drag Radials next week. I am really enjoying being middle-aged.
Study common chemical names for methanol, research the MSDS (Material Safety Data Sheet) for a specific product and you'll discover that you can buy it @ Wal-Mart!!!
All I know is that my Novi 1500 making 11 PSI thru an air to air and a single nozzle meth set up sees IATs that are BELOW ambient. That in itself should make it a no brainer for any FI set up. I'm not even going to get into what kind of gains the N2O guys in ADRL are seeing from a small shot of meth.
Not quite meth
I don't like Meth Injection at all!!! Have come to the realization that on this platform it's needed due to the heads and hot spots. I don't like adding variables and this is just another variable that can fail. I would much rather not use it that use it!!
If I do go SC shoot the crank is already pinned for it.............I will be adding a meth kit!
We have EVO's 2.0L 4 cylinders pushing 625 on 93 octance, GTR's 3.8L 6 cylinders pushing 1000awhp on 93 octane, Supras the same.............etc etc. I do with this platform was the same way!!!
Denatured Alcohol MSDS: ttp://www.rockler.com/tech/RTD20000136AA.pdf
50% methanol/ 50% ethyl alcohol
Don't forget Mineral Spirits: 100% Methanol
In Deep South Texas I have to order VP Methanol and shipping costs me as much as the Methanol. Basically $90 for 5 gallons. Therefore, I have look for options.
Food For Thought
Food For Thought
Denatured alcohol is used as a solvent and as fuel for spirit burners and camping stoves. Because of the diversity of industrial uses for denatured alcohol, hundreds of additives and denaturing methods have been used. The main additive has traditionally been 10% methanol, giving rise to the term "methylated spirit."
Not quite meth
Not quite meth
Food For Thought
Food For Thought
When all else fails another fluid you can use and count of finding locally with no problem is denatured alcohol. Denatured alcohol can be purchased at any Home Depot, Lowes and many other home improvement stores and is located in the paint department.
What is denatured alcohol you ask? Denatured alcohol is generally 90% ethanol with 10% methanol added to it to render it undrinkable for human consumption. While ethanol does not offer as good of a cooling effect as does methanol. Ethanol does have more power per unit volume then methanol. However, methanol is still the preferred choice over the two alcohols.
Source: http://www.alcoholinjectionsystems.com
I think I'm good I'm only running 7psi on my centri. It's a great alternative that requires no mixing. It's the same with windshield washer fluid. As long as the tune can take it then you can use it. My car was specifically set up for denatured alcohol in mind.
All this talk about alky/meth I wanted to chime in about my recent experience with e85. We tuned the car to run with 5 gallons of gas an then ran that tank out on the dyno to simulate some drive time. Then we put in 10 gallons of e85 adjusted tune and engine temps dropped and all of a sudden the exhaust smell from having no cats went away. Pretty interesting to see it happen like that. Even the fuel feed lines were cooler than I expected.
Im a big fan I'v made over a 1000+ on 93 and Meth. But it isn't fool proof lol! You can have the pump not come on or something like that lol! Ask me how I know lol! I was lucky, but it could have been bad!
Which meth system were you using? Why didn't the pump come on ?
