How much power are you going to be running with the butt mount gameover? Ill take a crack at it if Im at your power level or close. I should have a little more this year. But changes to the event are coming and it will be based on MPH from my little birdy named Amar lol
Lol the butt mount that might not EVAR spool. Umm the turbo is rated for 2k but I won't be able to make that much jam and keep a 6spd together. I honestly have no clue what it will make. I went smaller cubes on the LSX block and running a little more CR that most would because of E100 24/7. If it makes 1300 or 1500 I'm cool either way just ready to have the car back and be able to enjoy it. I'll be down to play at TI or even in Houston in March you'll probably mop the floor with me haha but it's all in fun. I've seen some of the new rules for the 2013 event already. It's not going to be to bad at all.
Do you guys think the 315-35-20 NT05R will hook better than 345-30-19??
We have had better luck with the 19s hooking better. On this run, the car hooked 2nd thru 4th,and we were running 14 lbs 1st and second gear and 18lb in 3rd and 4th. We tried running 18lbs in 1st and 2nd, and it just blew the tires off so we shut it down. They wouldn't let us run again after the 163.
