"SINISTTERC6 Twin Turbo"
#46
Mount it to the roof. That would be sweet. Just gravity feed to the motor.
#54
I tried, it didn't give us enough capacity. If you have to know we welded a trailer hitch and Ill just pull a trailer that holds the tank. This is a great idea because for one I can readily switch fuel types without worrying about tank contamination, second it allows me unlimited range so that I can drive to and from anywhere in the country. Finally we created a quick release so in the event Im loosing a race I can release the trailer, dropping 200lbs and giving me the edge. Im telling you after my car I cant imagine anyone installing a fuel tank in a car again.
#55
#56
Sinister, whats the advatange of mounting the turbo in place of the fuel tanks compeard to at the back? Just thinking you nw have to relocate the fuel cell for a minor saving in pipe length back to the turbo (if mounted in the rear).
#57
Im hoping the fuel cell sitting behind the rear axle shifts the weight balance to a point that is favorable for traction. The fuel cell allows for easier pump changes as well as no limit to how big we can go and I can drain the tank to swap fuels fairly quickly. But mainly the idea of side pipes is what sold me, just imagine a corvette bouncing a 2 step throwing flames out the side before launch
#58
love it... I was thinking about this as I was looking at my car w/ no fuel tanks doing the fuel system for my build.
Turbos where the tanks were, fuel cell where the muffers were, plenty of space for everything and potentially a larger fuel capacity if running something like E85 (not sure if it applies to you).
In for results.
In for results.
#59
In for results.
In for results.
#60
