ProCharger 8" balancer/4" blower 8-rib direct drive belt (K080537HD or K080545HD?)
My direct drive instructions recommend this belt size for 3.60-4.00” blower pulley and 8.0” balancer w/ 10-rib
K100540HD:
Effective Length (in) 53.96
Effective Length (mm) 1370
Number of Ribs 10
Outside Circumference (in) 54.5
Outside Circumference (mm) 1385
Unforutnately there is no '540' in an 8-rib.
There are only these 2 options:
K080537HD:
Effective Length (in) 53.71
Effective Length (mm) 1364
Number of Ribs 8
Outside Circumference (in) 54.272
Outside Circumference (mm) 1379
K080545HD:
Effective Length (in): 54.50
Effective Length (mm): 1384
Number of Ribs: 8
Outside Circumference (in): 55.125
Outside Circumference (mm): 1399
Is anyone running either of these? I'd rather order one that's known to work vs. trial and error.
K100540HD:
Number of Ribs 10
K080537HD:
Number of Ribs 8
K080545HD:
Number of Ribs: 8
It is tedious, but it won't impact the integrity of the belt. It has been done and was used before the direct drive hit the market when doing full 10 rib conversions.
I would use the 54.5" belt and give it a go. The suggestions are just that. I bet you will find it works just fine. One thing I have considered doing when on the margin like you are is possibly using a smaller idler pulley than stock. Metco makes 50 and 100mm idlers and Lingenfelter sells a 76mm, so I wonder if utilizing one of these would allow you to use a longer belt (bigger idler) or shorter belt (smaller idler) and maybe even gain belt wrap.
Jason
Jason
