Aftermarket alternator
Lot of threads about that but is there any proven (issues free) alternator for c6 corvette?
I have additional electronics like:
Externel fuel pump
EWP
Four fans
Four gouges
Exhaust cutout
Alky meth
TCM 2000
Pioneer unit and two speakers
Not sure what else!
What brand is recommended and what amp?
(what is the stock amp?)
Externel fuel pump
EWP
Four fans
Four gouges
Exhaust cutout
Alky meth
TCM 2000
Not sure what else!
ok, when was the last time you had a Generator in your car as opposed to an Alternator???
if you look up parts in the GM part list, if you look for Alternator.. you find nothing!
they are listed under Generator. (i know they generate.. lol)
GENERATOR. Engine Electrical
GENERATOR,(ACDelco #25888970). GENERATOR, Engine Electrical. For: Y 110 AMP GEN(K63) (2005-2005) (2005 - 2008). Required: 01
GENERATOR,(ACDelco #25888970). GENERATOR, Engine Electrical. For: Y 110 AMP GEN(K63),6-SPD AUTO TRANS(MYC) (2006-2012) (2005 - 2008). Required: 01
GENERATOR,(ACDelco #25888970). GENERATOR, Engine Electrical. For: Y 110 AMP GEN(K63),6-SPD AUTO TRANS(MYC) (2006-2012) (2009 - 2012). Required: 01
GENERATOR,(ACDelco #25888970). GENERATOR, Engine Electrical. For: Y 110 AMP GEN(K63),6-SPD M/TRANS(MM6),(MZ6) (2006-2012) (2005 - 2008). Required: 01
GENERATOR,(ACDelco #25888970). GENERATOR, Engine Electrical. For: Y 110 AMP GEN(K63),6-SPD M/TRANS(MM6),(MZ6) (2006-2012) (2009 - 2012). Required: 01
It seems the DP performance are using the nations alternator, I might go with their xp290 amp series.
Anyone tried the DC power alternators?
Thanks all for the help and recommendations!
Now my next step to see what is the size of those alternator + how to make a bracket as the stock alternator now has no clearance with my taller valve cover
Call dallas performance.The one they stock works flawless. My volts are rock steady at any RPM range. With the stock one i was bouncing all over the place. Car was getting stranded on the road.i have the following
twin fuel pumps
huge menzeire water pump for the air to water intercoolers
turbowerks oil pump for turbos
alky control meth kit
twin fuel pumps
My system randomly loses 2-3 volts while idling, which makes the idle dip to 600-700rpm. It's worse with AC on. I haven't replaced my battery yet, so I don't know if it's actually my alternator.
I joke that the alternator is the only factory thing under my hood, and this thread has me wanting to upgrade.
