how much power can you make with a e-force
what are some of the highest numbers you guys are making with a LS3 stock bottom end and a e-force supercharger? mine was at 680 rwhp before we pulled the heads off to port them. curios to see how far others have pushed these blowers. not so much curios what the bottom end can hold as how much power the eforce can make on 6.2L
custom ground cam
1 7/8 kooks headers catted
corsa sport mufflers
alky controls meth kit
85# injectors
9.5 psi
coming soon ported heads, LS9 head gaskets, arp studs, LSA lifters ,comp cams rocker trunion upgrade and going from 3'' pulley to 2.75''
custom ground cam
85# injectors
9.5 psi
My first post! I have attached a link to one of my dyno runs. The car makes 710 rwhp and 730 lb ft of torque at 3,500 rpm. I could probably pick up another 70 hp or so with alc/meth injection.
https://www.youtube.com/watch?v=wS8yzsg-6V4
Jody is right on at 700h.p or slightly more.That is pretty much it for an e force according to what i ve been told.700 h.p. and traction makes for a very fast ride.On the street anything more is overkill.
