C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
New build f1c Procharged 402
Old 05-10-2013, 12:48 AM
03justin
03justin's Avatar
Default New build f1x Procharged 402
Finally getting around to post a build thread:
Engine is a ls2/402ci
Callies Dragon slayer crank
Callies I beam rods
Diamond coated pistons w/tool steal rist pins 9.5:1
Total seal rings
Cometic head gaskets
Morel lifters
Harland sharp rockers
Arp main studs
Arp head studs
Melling oil pump
Trick flow tea 235's
Fast lsxr 102
Tpis 102 throttle body
Arh 2" headers
Katech valve covers w/coil relocation kit
Zr1 exhaust
Cooling:
Dewitt's cut down radiator
Dual Spal fans
Meziere electric water pump
Induction:
F1x Procharger
Ati 8 rib dampner
8 rib Direct drive
Dallas performance big mouth inlet
Race blow off valve
Fuel system:
Hob eleminator fuel system
Id1000's
Fast rails
Alky dual nozzle meth kit
Driveline:
Rpm lvl 7 4l65e trans w/6 pinion planet
Pi triple disk 3400
Rpm lvl 4 diff 3:42's
Dss 3.5" drive shaft
Rpm couplers,fly wheel and drive shaft coupler
C5z axles(for now!)
Ecs loops
Rpm power glide,coan coverter and c6z lvl 4 diff coming soon!!!
Suspension:
Pfadt coilovers and rear drag bar
Pfadt motor and trans mounts
Lg spindles
Rsd 6 point cage
Rts beadlocked 15x10
Micky Thompson pro 275x/325 radials
Aluma star 17's
Pics coming soon!
Old 05-10-2013, 01:07 AM
Detoxx03
Detoxx03's Avatar
Nice mod list. No point in that fast intake for boost and might want to look into the hob fuel system since some have issues with them. Best of luck on everything and can't wait to see what it does.
Old 05-10-2013, 01:17 AM
winters97gt
winters97gt's Avatar
Sounds like a solid setup. Good luck!
Old 05-10-2013, 01:25 AM
03justin
03justin's Avatar
Thanks man.if I keep the car later this year I'm going 427 lsx and ill do a sheetmetal or carb'd intake an elbow.but shouldn't have a problem at my boost the cars a 05 and my tuner said with the sd he wouldn't be able to see boost above 18-20psi.so ill have to put a new computer system in the car.but should be enough to go hurt people's feelings at the pad!
Old 05-10-2013, 07:13 AM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
That should be a monster. Good luck and looking forward to seeing it get done !!
Old 05-10-2013, 07:41 AM
helga203
helga203's Avatar
I have a 99 C5 and my SD tune stock pcu with my f2 seeing 30psi boost??????? Noproblems here.
Old 05-10-2013, 07:53 AM
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Sounds like an awesome build!
Subscribed for the results.
Old 05-10-2013, 10:41 AM
Detoxx03
Detoxx03's Avatar
Who's your tuner?
Old 05-10-2013, 11:05 AM
03justin
03justin's Avatar
I haven't made my mind up yet on a tuner,but I've talkd with Geoff and futral.
Old 05-10-2013, 11:36 AM
Detoxx03
Detoxx03's Avatar
Well you know where I stand on that.
Old 05-10-2013, 01:00 PM
turbotuner20v
turbotuner20v's Avatar
HP goals? How much is a 4l65e good for?
Old 05-10-2013, 01:28 PM
b16gsr
b16gsr's Avatar
looking forward to this
Old 05-10-2013, 01:43 PM
03justin
03justin's Avatar
As much power as I can!the trans is a rpm lvl 7 but I'm switching to a power glide and keeping the 4l65 for a spare
Old 05-10-2013, 01:53 PM
turbotuner20v
damn... that's going to be a beast at the track.
Old 05-10-2013, 03:03 PM
03justin
03justin's Avatar
Thanks guys.hopefully I can Finnish getting it together in the next few weeks.the only thing I haven't got yet is a catch can setup.what kinda setup are you higher hp running or y'alls boosted setups?
Old 05-10-2013, 04:35 PM
ajrothm
ajrothm's Avatar
Why you gonna put the 4l60 on the back burner so soon? Ofcourse the glide will be stronger and consume less power but.... You'll probably 60' better with the 4l60 and still have OD for cruising...
Just curious.... Unless this is a max effort type deal, then I can understand the glide... (But not the F1c at that point)..
Get some pics posted up when you can..
Old 05-10-2013, 08:44 PM
03justin
03justin's Avatar
im not giving up on the 4l65.jts just i dont want to take a chance on breaking it when there's a bunch of money on a race.detoxx knows how they get around here in N.O!
To New build f1c Procharged 402
Old 05-10-2013, 08:55 PM
03justin
03justin's Avatar
got the back wheels mounted today!the alluma stars should be here monday.
Old 05-10-2013, 10:59 PM
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
Looking good. What fuel are you going to use? Not a fan of the pump setup. Cartech flip drive?
Old 05-10-2013, 11:14 PM
03justin
03justin's Avatar
A friend of mine is a shell urt dealer here in town so I'm take his word on it and try it out.through this whole build the pump has been on my mind from the day I bought it.fingers crossed on that!yep cartek flip.
Quick Reply: New build f1c Procharged 402
