C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Rear end gear ratios
Old 11-01-2013, 07:07 PM
jacked cobra
jacked cobra's Avatar
Default Rear end gear ratios
What rear end gear ratios are you supercharged c6z guys running. I have stock ratio, I'm at 800rwhp and running 143mph in the quarter thought it would be higher.
Old 11-01-2013, 07:12 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
99.9 are going to be running stock since no one makes anything else. You can adjust it slightly by running a taller or shorter tire. The other option is to switch to a base diff then that opens a few options up but most z06 guys aren't going that route, especially with high power.
Old 11-01-2013, 07:35 PM
jacked cobra
I'm running hoosier 335/35 18. Right now. Do u think 143 is low for 800rwhp?
Old 11-01-2013, 07:45 PM
NSANEC6
NSANEC6's Avatar
Honestly I do not think 143 is bad at all for 800 rwhp car. What are your 60's?
Old 11-01-2013, 07:51 PM
jacked cobra
Bad 1.9-2.0. Not getting any runs cause I keep getting banned before I get the launch down. Need to go to a track rental. 60ft shouldn't affect mph on top end by much.
Old 11-01-2013, 08:02 PM
Ensoniq
Support Corvetteforum!
Ensoniq's Avatar
I think its RPM transmission that makes different ratio trans gears. An alternative to the lack of ring gear option for the C6Z
To Rear end gear ratios
Quick Reply: Rear end gear ratios
