C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
A little tip for C6's that run hot
Old 04-03-2014, 11:23 PM
  #41
JMBLOWNWS6
JMBLOWNWS6's Avatar
I did this to two cars last year and they are running great. You can def hear the spal fans running at a higher rate of speed thru a dual relay harness.
Old 04-04-2014, 08:24 PM
  #42
ZBADESTZ@Straightline
ZBADESTZ@Straightline's Avatar
Are they still controlled thru the computer?
Old 04-06-2014, 02:45 PM
  #43
Chicago1
Chicago1's Avatar
So what parts are needed for plug and play?
Old 04-07-2014, 04:41 PM
  #44
george536
george536's Avatar
would like part list and/or diagram if possible
Old 04-07-2014, 10:22 PM
  #45
x3
Old 04-08-2014, 05:20 AM
  #46
ANGRY Z
Support Corvetteforum!
ANGRY Z's Avatar
Good stuff ECS.
Old 04-08-2014, 06:11 PM
  #47
WHITE_SHARK
WHITE_SHARK's Avatar
Originally Posted by ZBADESTZ
x3
x4,,, part list please
Old 04-09-2014, 12:14 PM
  #48
5 Liter Eater
5 Liter Eater's Avatar
St. Jude Donor '11
Um, two (or one if you have the stock fan) relays and some wires.
Old 04-09-2014, 12:33 PM
  #49
Chicago1
Chicago1's Avatar
we need visual and diagrams man.
Old 04-09-2014, 12:38 PM
  #50
george536
george536's Avatar
Come on you know we need our hands held through it
Old 04-11-2014, 10:05 AM
  #51
wolf8218
wolf8218's Avatar
I agree with the rest of the dufuses in this thread, I don't know anything about wiring. Pics and diagrams please!
Old 04-11-2014, 11:24 AM
  #52
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Just order the painless kit and wire it in. If you want it switched off the stock ECU then do what was posted earlier in this thread, or just tie it to a new switch.
Old 04-11-2014, 11:34 AM
  #53
zuluvett
zuluvett's Avatar
painless kit ?? ^^^
Old 04-11-2014, 12:12 PM
  #54
Unreal
Unreal's Avatar
Posted it earlier in the thread.
Old 04-12-2014, 04:48 AM
  #55
wolf8218
wolf8218's Avatar
Which one would I use if I just want to have a toggle for 100% fan throttle for traffic/high energy driving? When the toggle is off I would like it to run as it would stock.
Old 04-15-2014, 06:30 PM
  #56
Unreal
Unreal's Avatar
That you just need to get a fan switch, nothing special to do that. Several vendors sell that. That being said, fans will be max where ever you program them to so for traffic/high energy it wouldnt do anything. Fan switch is good for keep fans on when car is off to cool off between runs. For what you are describing there is zero advantage.
Old 04-15-2014, 10:20 PM
  #57
383
383's Avatar
I have a Caspers electronics manual fan switch that does just that. Hi and Low or stock.
http://www.casperselectronics.com/st...oducts_id=1473
To A little tip for C6's that run hot
Old 04-17-2014, 12:45 PM
  #58
wolf8218
wolf8218's Avatar
What about the original post stating that the original ground wiring for the fan motors is not sufficient and wouldn't power the motors to 100% capacity?
Old 04-17-2014, 01:30 PM
  #59
5 Liter Eater
St. Jude Donor '11
I don't think it's the ground thats the problem as much as how the connection for the ground burns up in the stock connector.
Old 04-17-2014, 01:47 PM
  #60
Chicago1
Chicago1's Avatar
Yeah we wanna know how to make them faster as stated earlier. Not just control folks are stating there fans runs at a higher speed then normal. That's what we are asking for.
Quick Reply: A little tip for C6's that run hot
