Nitrous Express Direct Port Install
Nitrous Express Direct Port Install on my 08 ZO6
I wanted something that looked as well as it performed. So I called up my good friends at NX. After discussing my wants and needs they came up with this four solenoid direct port system, which i think looks awesome.
Why NX?
Made in the USA, Technical help is just a call away, the best customer service I've ever had, and the quality and value of the products they sell. If you need anything Nitrous give them a call or shoot me a PM.
I'm running the Maximizer 4 progressive nitrous controller mounted in the glove box. This controller can do everything from rpm, tps, mph, time, boost, and afr correction.
I wanted a nice clean install so i ran all the wires to the ecm.
tps- C2 Pin 63
rpm-C1 Pin 48
vss- C1 Pin 57
I ran all the wires and nitrous line through the firewall behind the dry sump tank.
Bottle is mounted behind the passenger seat where i can turn it on if the need arises and also hidden when the hatch is shut.
Some finished pictures
Shoot me a pm if you need anything Nitrous.
Why NX?
tps- C2 Pin 63
rpm-C1 Pin 48
vss- C1 Pin 57
Any runs at a track with your set up yet? I'm sure lots of us would like to know.
I agree with everything you said about Nitrous Express here's some of my kit, nothing as pretty as yours
pressure regulated heater
msd dual rpm switch and wideband
cup holder switchplate
nozzle and high pressure fuel cell c16 all dialed in and ready to go fast, never ran it at the track never needed it on the street, but is armed and ready if need be
