supercharger with n/a cam?
I'm about to pull the trigger on a sc here shortly, but my 08 base mn6 car has a cam designed for na application. My concern is what are or would be the effects with boost. I have an ls7 cam on hand as well that seems more sc friendly. I plan to run the stock boost for now.
Current cam specs are 230/240 609/588 114+3. My car has been as fast as 11.32@123 in the 1/4 mile. What should I expect as far as hp? My car also has full exhaust and ported tb. I have a 25% ud pulley that I know that needs to come off.
Any ideas? Suggestions?
I would leave it in. It's not that far off from an aggressive blower grind. Lift isn't too crazy either.
Quick tip on a new crank pulley. ATI has an Ebay store where they sell "blemish" pulleys. I got my 7.5" ATI crank pulley for less than half of retail. It has a scratch on the back side of the pulley that you can't even see.
nmalik3000 (05-15-2019)
Im going to check out that store. Thanks!
Former Vendor
is it an ideal cam no. but it will work just fine Your still on the stock motor so it will still take boost great even with that cam with no issues.
I know tht ECS kit is calling your name
It really isnt too far off at all. Keep it
Epi
If you wanted to put it on kill and you went with an ECS1500 setup with no inlet restrictor plate you would be around 750rwhp with methanol injection and pump gas.
With the inlet restrictor probably around 625-650rwhp and about the same torque.
Sweet! Well I just ordered the ECS kit!! I'm going to take it easy for now. I'm not in a hurry to make a lot of power that can become potentially useless. As it is these vettes are no joke with a few bolt ons, so I can't imagine what they're capable of at 600rwhp!
I'm currently deployed, so I won't be able to install and tune for now until I get back. I'm sure the wait would be well worth it. Thanks for your input!
Epi
Epi
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
Epi
Epi
Former Vendor
You will love the kit EPI!!! Better hope you dont make your wife made while your over there and see goes and sells it cheap
Thanks for trusting me with your order man!!! Be safe over there!!
Not a problem! I've heard your name for a while before you became a vendor. So I feel that I needed to give you my business to help you in your endeavor. It was nice to talk to you.
Thanks!
Can i piggy back on this thread? I have a 222/228 x 114 +4 (.578/.561) cam on an otherwise stock LS2 with long tube headers. I am contemplating going with an eforce. I was thinking about going back to the stock cam. Other than adding more power how does the supercharger effect the cam? Does it even out lope?
Thanks! that helps. Do you know if the Eforce tune will work with a cam? I guess what i am asking is.... how good is the included tune? is it for a "stock" car? Is a dyno tune a must after adding the eforce with a cam?
The canned tune is for a stock engine. I would just get the Edelbrock tuner kit that doesn't come with the canned tune and have your choice of tuner tune the car.
That doesn't mean that is going to run great with the cam either. Personally I would start the engine with the included tune, stay off boost and take it for a real tune. Not only would it help power wise, but drivability too.
Hope that helps.
